it is too fast to use F200 with G2?
- curran209
29 Sep 2021 06:59 #221805
by curran209
it is too fast to use F200 with G2? was created by curran209
We use G2 R5 draw circle,start point is 370,-280, point1 is 380,280, point2 is 370,-280, With F600 circle degree is 0.3. F50 circle degree is 0.1. F10 circle degree is 0.03. does the G2 can't use F200, it is too fast bad effect if used it?
F600 G2 X380 Y-280 R5
F600 G2 X370 Y-280 R5
F10 G2 X380 Y-280 R5
F10 G2 X370 Y-280 R5
01 Oct 2021 14:22 #221958
Replied by andypugh on topic it is too fast to use F200 with G2?
I am not 100% sure what you are describing, but F200 (or F20000000) should be fine on a machine that is capable of that.
It is likely that your machine acceleration limits are not high enough to perform the moves programmed.
linuxcnc.org/docs/2.8/html/user/user-con...#_trajectory_control
Might be useful to read.
- curran209
15 Oct 2021 03:12 #223156
by curran209
Replied by curran209 on topic it is too fast to use F200 with G2?
I increased acceleration limit, but it didn't to be good. There is no these content in my ini flie, does it related to this issue?
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 0
ARC_BLEND_OPTIMIZATION_DEPTH = 50
ARC_BLEND_GAP_CYCLES = 4
ARC_BLEND_RAMP_FREQ = 100
- robertspark
- Thank you received: 216
15 Oct 2021 05:29 #223168
by robertspark
Replied by robertspark on topic it is too fast to use F200 with G2?
G64 tolerance will affect motion and accuracy.
what type of machine are you running?
mill, lathe, plasma, router????
what steps per unit are you running?
what units?
what are you driving? steppers, servos?
what is your drive (rack and pinion, belts, ball screw, acme / trapezoidal screw, )?
what units?
- curran209
15 Oct 2021 05:55 #223170
by curran209
Laser machine tool, x y axis Linear motor, z axis rotary motor, z axis ball screw, all is servo driving. laser in on the z axis.
# Introductory graphic
INTRO_TIME = 5
#EDITOR = gedit
TOOL_EDITOR = tooledit
INCREMENTS = 1 in, 0.1 in, 10 mil, 1 mil, 1mm, .1mm, 1/8000 in
# Trajectory planner section
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
INTRO_TIME = 5
#EDITOR = gedit
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
16 Oct 2021 22:41 - 16 Oct 2021 22:42 #223330
The acceleration needed to go round a circle or radius R is v^2/R
(velocy in m/s, radius in m)
For your test case, what is the result of the calculation above? What is the max acceleration in your INI?
Last edit: 16 Oct 2021 22:42 by andypugh.
- curran209
18 Oct 2021 02:58 #223431
by curran209
the result of the calculation v^2/R is 2m/s^2, the max acceleration in my INI is 600, but the circle be more not round when i bigger the acceleration in UI. The circle to be more bad round when i set max acceleration to 2.5m/s^2 on UI than using default max acceleration.
[AXIS_X]
MAX_VELOCITY = 100
MAX_ACCELERATION = 600.0
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
[AXIS_Y]
MAX_VELOCITY = 100
MAX_ACCELERATION = 100.0
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
[AXIS_X]
MAX_VELOCITY = 100
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
[AXIS_Y]
MAX_VELOCITY = 100
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
- curran209
18 Oct 2021 03:12 #223432
by curran209
x axis MAX_ACCELERATION = 600.0
y axis MAX_ACCELERATION = 100.0
- robertspark
18 Oct 2021 06:13 #223434
by robertspark
your limiting acceleration will be Y given it is smaller
- curran209
18 Oct 2021 07:02 #223436
by curran209
I changed Y axis MAX_ACCELERATION = 600.0,but it more bad.
Time to create page: 0.108 seconds
