linuxcnc 2.8.2 no nm connection edit
5 years 1 week ago #224082 by tommylight
Computer IP must be anything but 10.10.10.10, so set it at 10.10.10.11.
Where did you get the info for setting it? I would really like to delete that as it is getting aggravating for us and for the users like you.
Thank you.
5 years 1 week ago #224276 by luap
High tommylight
excuse please when i have agressive. That i would not. The 10.10.10.10 stands in the Mesa datasheet and talla 83 had it two. But tomorow i will try your 10.10.10.11.
Thank you very much                         luap
5 years 1 week ago - 5 years 1 week ago #224289 by PCW
Mesa FPGA card has a 10.10.10.10 address but the PC must
have a different address (but be on the same subnet), so
tommylights 10.10.10.11 should work on the PC as would
10.10.10.XXX as long as XXX is not 10, 0, or 255.
10.10.10.1 will work but is not suggested.
Last edit: 5 years 1 week ago by PCW.
5 years 6 days ago #224342 by luap
High PCW
i tested tommylights 10.10.10.11, but the same No 7i92 Bord found and IP a the same just the differenc in the last number 11. Please have a look in the attachment. The ethernet has a hole other Number. What makes it that my system denies to read the board 7i **. If i kow it i would not ask fore help. Thank you very much fore help me
All good to you                               luap
 [attachment=41105]No Board Ipa.pdf[/attachment
5 years 6 days ago #224432 by PCW
Can you post the result of running this command:
ip a
Thanks!
4 years 11 months ago #224973 by luap
Hallo
i thaught i had it attached in an .pdf. I hop now it will work.
Thank you very much fore help me.
Time to create page: 0.151 seconds
