linuxcnc 2.8.2 no nm connection edit
- luap
08 Oct 2021 04:41 #222518
by luap
linuxcnc 2.8.2 no nm connection edit was created by luap
Hello linuxcnc friends
i hopefully downloaded linuxcnc 2.8.2. But than the shock when i connect my 7i92 to the ethernet connector i could not edit the connection words. i tried to update and to download and other try's i gave up. Now i ask you fore help to get that thing to run.
Please help to succes.
Thank you in advance
luap
luap
- Thank you received: 7490
08 Oct 2021 10:00 #222535
- hhogendoorn
- Thank you received: 3
10 Oct 2021 07:02 #222716
by hhogendoorn
Replied by hhogendoorn on topic linuxcnc 2.8.2 no nm connection edit
I downloaded on Debian 10 : Network Manager GNOME, easy to adjust your IP settings and all networks are visible.
Good luck Hans
Good luck Hans
- luap
12 Oct 2021 12:53 - 12 Oct 2021 13:08 #222931
by luap
Replied by luap on topic linuxcnc 2.8.2 no nm connection edit
with Synaptic Package manager i deleted the nm tray and installed network-manager and network-manager-gnome. I can manuell change between the ethernet and the 7I92 works fine. With ping 10.10.10.10 works also fine but mesaflash and hm2 have problem the all known no 7I92 board found. The connection manager knob above right says 7I92 connected. Has any one a idea what i did wrong ore what else to install? i at end i do not know further.
Many thank and many thank in advavance
luap
luap
Last edit: 12 Oct 2021 13:08 by luap.
12 Oct 2021 14:33 #222939
Replied by tommylight on topic linuxcnc 2.8.2 no nm connection edit
In a terminal
ip a
Paste the result here.
ip a
- luap
24 Oct 2021 09:03 #224074
by luap
Hallo tommylight
thank you fore youre help. Here is the ip a output :uhu@uhu:~$ ip a1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00inet 127.0.0.1/8 scope host lovalid_lft forever preferred_lft foreverinet6 ::1/128 scope hostvalid_lft forever preferred_lft forever2: enp1s0: mtu 1500 qdisc pfifo_fast state UP group default qlen 1000link/ether 38:d5:47:16:f9:a3 brd ff:ff:ff:ff:ff:ffinet 10.10.10.10/8 brd 10.255.255.255 scope global noprefixroute enp1s0valid_lft forever preferred_lft foreverinet6 fe80::2265:82f9:7b9c:c6d0/64 scope link noprefixroutevalid_lft forever preferred_lft foreveruhu@uhu:~$p { margin-bottom: 0.25cm; line-height: 115%; background: transparent }Thank you very much luap
24 Oct 2021 10:56 #224082
Computer IP must be anything but 10.10.10.10, so set it at 10.10.10.11.
Where did you get the info for setting it? I would really like to delete that as it is getting aggravating for us and for the users like you.
Thank you.
Thank you.
- luap
25 Oct 2021 15:49 #224276
by luap
High tommylight
excuse please when i have agressive. That i would not. The 10.10.10.10 stands in the Mesa datasheet and talla 83 had it two. But tomorow i will try your 10.10.10.11.
- Thank you received: 5334
25 Oct 2021 18:44 - 25 Oct 2021 18:44 #224289
Replied by PCW on topic linuxcnc 2.8.2 no nm connection edit
Mesa FPGA card has a 10.10.10.10 address but the PC must
have a different address (but be on the same subnet), so
tommylights 10.10.10.11 should work on the PC as would
10.10.10.XXX as long as XXX is not 10, 0, or 255.
10.10.10.1 will work but is not suggested.
Last edit: 25 Oct 2021 18:44 by PCW.
- luap
26 Oct 2021 07:54 #224342
by luap
High PCW
i tested tommylights 10.10.10.11, but the same No 7i92 Bord found and IP a the same just the differenc in the last number 11. Please have a look in the attachment. The ethernet has a hole other Number. What makes it that my system denies to read the board 7i **. If i kow it i would not ask fore help. Thank you very much fore help me
All good to you luap
[attachment=41105]No Board Ipa.pdf[/attachment
Time to create page: 0.443 seconds
