linuxcnc 2.8.2 no nm connection edit
- luap
02 Nov 2021 16:11 #225007
by luap
Replied by luap on topic linuxcnc 2.8.2 no nm connection edit
Thank you all very much
I tried the netmask set to 24 but same ip a output as above. no board 7i92 ....... is also with mesaflash. ip a sets it automatically to/8.
Thank you very much
Thank you very much
- Thank you received: 5321
02 Nov 2021 16:39 #225009
Replied by PCW on topic linuxcnc 2.8.2 no nm connection edit
So are you saying
ping 10.10.10.10 works but
mesaflash --device 7i92 --addr10.10.10.10 --readhmid
returns
No 7I92 board found
returns
No 7I92 board found
- luap
03 Nov 2021 13:23 #225104
by luap
Hello
yes sir so is it. But from the begin of this thread is it so, even with ADR 10.10.10.10, 10.10.10.11 . The netmask is automatically set. Is the GNom IDE from Synaptik others then the Download version ?
Thank you very much
luap
Thank you very much
luap
03 Nov 2021 14:18 #225107
If the PC address is 10.10.10.10, ping will work even if no 7I92 is connected.
(the PC is pinging itself)
What does
mesaflash --device ethernet --addr10.10.10.10 --readhmid
report?
What do the 7I92 LEDs do when you ping the card?
What does
report?
- luap
04 Nov 2021 07:45 #225206
by luap
Hello PCW
With ping or without ping the left LED in Front to ethernet jack is slow flashing and the LED on board are counting in 4 bit hex format up until new. With addr the readhmid now works fine that is new. Thank you a lot now is light in the tunnel.
once Thank you from heart.
luap
luap
- luap
04 Nov 2021 07:59 #225208
by luap
Hello a gain
I disconnect the ethernet jack from the board and ping the card. The answer is: " no network reachable"
Thank all of you
luap
Thank all of you
luap
Time to create page: 0.107 seconds
