Errors at random times (and how to find help with hardware)
31 Oct 2021 23:52 - 01 Nov 2021 12:25 #224819 by bevins
What screw are you talking about.
If you look at the picture there is a label "V+ ADJ"... and under that label there is a green LED light and a plastic potentiometer screw. So I played with this yesterday. This is on the CNC board, not in the PC.
All 24V power supplies i use can go from 18.2V to 27.8V, still within range of everything attached to it.
This is somewhat comforting. I'll do the things both of you said about the PC power adapter and the 5i25 card and will report here if anything changes.
bevings, thank you so much for offering the help. I'll send you a message to discuss this option.
What Tommy said. The range of that pot [probably wont go high or low enough to do anything. Just stick a meter on it and adjust it to 12 or 24vdc . Whatever it is suppose to be.
Last edit: 01 Nov 2021 12:25 by bevins.
04 Nov 2021 05:57 - 04 Nov 2021 05:59 #225201 by mitirino
Hi
Thank you all for all the advice and patience when repeating frew things multiple times.
I think it worked.
I removed the Mesa 5i25 card and cleaned with an alcohol wipe.
This seemed to have improved it a little as it ran for 5-6 minutes. Previously it would throw the errors after a minute I think... sometimes even less.
But as I just started getting happy, it threw the errors again.
So then I replaced the power supply, this time the proper power supply of the PC box, and this seems to have fixed it.
It ran for 25 min or so without the errors. I guess it will have to run for a few hours without throwing them, but 25 min is pretty comforting so I think it's fixed.
Thanks a lot. This was amazing!
Last edit: 04 Nov 2021 05:59 by mitirino.
  • Moderator
  • Moderator
04 Nov 2021 11:35 #225228 by tommylight
Check if you have disabled "hyperthreading" in PC's BIOS, also should disable anything regarding power savings and virtualisation.
Failing hard drives will also cause latency issues, but this does not seem to be it.
The following user(s) said Thank You: mitirino
04 Nov 2021 12:24 #225233 by mitirino
Thank you! I'll check these. I have not done anything on the PC myself, but will check if these have been disabled.
Time to create page: 0.145 seconds
