Abnormal sound of machine tool
- Thank you received: 7468
08 Dec 2021 06:24 #228604
Replied by tommylight on topic Abnormal sound of machine tool
I will get my big headphones later and give it another go.
The following user(s) said Thank You: wang
- wang
08 Dec 2021 06:39 #228606
by wang
Replied by wang on topic Abnormal sound of machine tool
I think this banging sound is related to the loss of the synchronization clock, so I want to use this link to solve it, but I am using a 2.9 environment and I don't have a 2.9 patch.
forum.linuxcnc.org/ethercat/35591-beckho...to-install?start=160
- 0x2102
- Thank you received: 88
08 Dec 2021 16:28 #228636
by 0x2102
Replied by 0x2102 on topic Abnormal sound of machine tool
As PCW asked, what is the latency on your system?
I had some strange noise on my testbench setup, when I used a PC with latency issues. Since I am using a PID for my test axis, I could see it in Halscope pid.x.error.
- wang
09 Dec 2021 01:02 #228666
by wang
- 0x2102
09 Dec 2021 20:01 - 09 Dec 2021 20:07 #228725
by 0x2102
Try this test: (maybe for 30 minutes or 1 hour)
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Download the script and run with sudo
forum.linuxcnc.org/media/kunena/attachme...09-30_2020-10-02.zip
The default latency test is too simple.
Also, download and install "ethtool" with sudo apt install ethtool and run
sudo ethtool -c "your nic card here"
Everything should be set to 0, if not you will introduce delay.
use this to change the settings:
sudo ethtool -C "your nic card here" rx-usecs 0
sudo ethtool -C "your nic card here" tx-usecs 0
as an example.
as an example.
Last edit: 09 Dec 2021 20:07 by 0x2102.
Time to create page: 0.127 seconds
