PMW signal mesa 7I76
4 years 11 months ago #225082 by elisa
PMW signal mesa 7I76 was created by elisa
Hi all,
I have a question: is it possible to get a PMW signal with different duty-cycle and waveform on a 7I76 MESA card?
Thank you.
4 years 11 months ago #225084 by PCW
Replied by PCW on topic PMW signal mesa 7I76
The step/dir outputs on a 7I76 are just 5V buffers so can output PWM
if desired (using firmware that replaces a stepgen with a PWMgen)
4 years 10 months ago #229625 by raychar
Replied by raychar on topic PMW signal mesa 7I76
Hi, I also want this feature. Don't understand "using firmware...".
Can it be implement in a .ngc program so i can use the program in the toolchanging operation. If possible, can you show how the program looks like?
Thanks,
4 years 10 months ago #229658 by PCW
Standard 7I76 firmware has 5 hardware step generators.
If you don't need all 5 Axis of motion you can install firmware on the
FPGA card that has say 4 Step generators and one PWM
generator, typically brought out on the 7I76s 5th axis step/dir pins
4 years 10 months ago #229737 by raychar
In 7i76e, i think there are 6 step/dir outputs for the drives, but i used up 5 for the 5 axis. I want to preserve the remaining one, as in case i need it in future. Instead, somehow, i intent to write a .ngc program to achieve the outputting a simple and rough pwm duty cycle, is it possible? but:..
>there are no time interrupt feature and goto function for use in Linuxcnc programming as what are in arduino and C language, aren't there ?
>the G4 dwell time limits to 1 second at minimum, isn't it, can i write
0.05 second in it?
4 years 10 months ago - 4 years 10 months ago #229739 by PCW
You can use LinuxCNCs software PWM component running at the servo
thread rate to generate PWM if you don't need high resolution or a high
base frequency.
man pwmgen
Last edit: 4 years 10 months ago by PCW.
Time to create page: 0.064 seconds
