Powering 7i76e board
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Nov 2021 00:24 #227255 by Aldenflorio
Powering 7i76e board was created by Aldenflorio
I have several questions, am I able to use either a 12v or 48v power supply? Along with that I find it quite confusing with the diagrams of how to wire up the THCAD-10 to the Mesa, along with that the wiring to the hypertherm 45 (not the xp one)
  • Moderator
  • Moderator
22 Nov 2021 01:02 #227258 by tommylight
Replied by tommylight on topic Powering 7i76e board
Use 12V. >>>>> 48V will kill the board!!!
THCAD FO+, FO-, GND, +5V
7i76e A+, A-, GND, +5V
  • Aldenflorio
  • Platinum Member
  • Platinum Member
22 Nov 2021 01:10 #227261 by Aldenflorio
Replied by Aldenflorio on topic Powering 7i76e board
The output of the power supply only has -v and +v
so do they go in the perspective a’s?
what do I hook ground to? And what do I hook +5v to?
22 Nov 2021 03:21 - 22 Nov 2021 03:25 #227268 by Benb
Last edit: 22 Nov 2021 03:25 by Benb.
22 Nov 2021 09:06 #227283 by rodw
Replied by rodw on topic Powering 7i76e board
I would buy a 24 volt power supply for plasma. This video I did covers all the connections
  • Aldenflorio
  • Platinum Member
  • Platinum Member
24 Nov 2021 00:15 #227460 by Aldenflorio
Maybe I should know this: though the output of the 12v power supply is -v and +v.
does -v go to +24v and +v go to ground?
  • Moderator
  • Moderator
24 Nov 2021 00:22 #227461 by tommylight
-V to GND
+V to +24V
You should really find someone who knows at least a bit of electronics.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
24 Nov 2021 00:36 #227462 by Aldenflorio
Yeah, I’ve built an entire working table from scratch already. This is my second. I just forget stupid stuff like this sometime
Time to create page: 0.189 seconds
