Converting an old DMU 50, where to start?
4 years 11 months ago #227872 by ihavenofish
so those 2 options effectively do the same thing, both ethernet solutions with 8 ports of serial expansion. option 1 is $30 cheaper. in around $500 total depending on how many extra io boards you end up needing.
you get 6 servo axes with encoder feedback. you need XYZ and Spindle, then you can add both your rotary table axes on if you can figure out how.
4 years 11 months ago #227881 by einarak
Thanks for the input, how does the 7i94 connect to the 7i77 since the 77 has db25 pin connector but 94 has ethernet and 26 pin idc
4 years 11 months ago #227960 by ihavenofish
other way round. the 7i94 is the "master" with the ethernet port.
4 years 11 months ago #227977 by Henk
Mesa can provide the connecting cable for that or you can make up your own. The pin out is in the manuals.
I use a ribbon cable and I mount the boards close together. The 26th pin on the idc is not used.
2 years 4 months ago #302446 by charlieLedezma
Hello, I would like to know if you managed to do this retrofit without changing the original drivers ? Could you update us ?
Time to create page: 0.282 seconds
