help makerspace linuxCNC lathe and mini mill, need to evaluate
- tater1337
- Thank you received: 3
03 Dec 2021 21:55 - 03 Dec 2021 22:41 #228315
by tater1337
help makerspace linuxCNC lathe and mini mill, need to evaluate was created by tater1337
I am getting more involved in our local makerspace and I have a few machines that I need help with
both have not had updates in years, and one had the OS updates sunset last year
specs on both machines are not very high, I think one has an atom processor
so I have three goals in mind
- identify the CNC interfaces, OS, and other hardware so we can get some documentation
- fix/update the OS'es so the machines can be run(and document)
- develop process documents and a tutorial plan so new members to the makerspace can learn to use the machines, with simple milestones from manual operation to full use of abilities
one is a Grizzly G8689 Mini Milling machine
the other I still need to fully identify, but I think it is a Sieg KC4S
I just scanned/found links of the documentation for the Grizzly, but there is no info about the CNC addon other than it is a dual core PC running linuxCNC
also I am not a linux expert
and I havent played with a mill in 30 years
I could almost say the same about lathes, except that I have been playing with our EMCO super 11 CD manual lathe
once we get these two up and running I have to tackle the leadwell 550D that also has been collecting dust
Last edit: 03 Dec 2021 22:41 by tater1337.
- Thank you received: 7465
03 Dec 2021 22:03 #228316
Replied by tommylight on topic help makerspace linuxCNC lathe and mini mill, need to evaluate
Pictures ?
- tater1337
03 Dec 2021 22:41 #228320
by tater1337
Replied by tater1337 on topic help makerspace linuxCNC lathe and mini mill, need to evaluate
added
- tater1337
03 Dec 2021 22:48 #228324
by tater1337
oh, data home for stuff
wiki.appletonmakerspace.org/Machining
04 Dec 2021 01:32 #228330
The big mill is begging to be retrofitted with LinuxCNC !
The best thing about LinuxCNC is that it can be used for all 3 machines, and for a makerspace that is hugely important.
- tater1337
04 Dec 2021 03:10 #228331
by tater1337
- tater1337
04 Dec 2021 03:23 #228333
by tater1337
and I think parts of it are very proprietary, and the new owners of it's IP are very anti right to repair
so it'll be left alone, until it's priority is increased
the big one should be a complete unit, so no need to retrofit linuxcnc unless there is a dang good reasonThe big mill is begging to be retrofitted with LinuxCNC !
04 Dec 2021 11:10 #228340
Oh good, they are using LinuxCNC already, one is on Debian wheezy and the other on Ubuntu 10.04.
- tater1337
04 Dec 2021 16:48 #228351
by tater1337
and the wheezy gets 404 errors when you try to update
both of which are things we want to fix in steps 1 and 2 (among other things)
bonus note, looks like the grizzly is using a parallel interface, which will be hard to upgrade without replacing the controller, once we can find out WHICH CONTROLER IT IS
you missed the bit about the ubuntu 10.04 is no longer supported for over half a decadeOh good, they are using LinuxCNC already, one is on Debian wheezy and the other on Ubuntu 10.04.
04 Dec 2021 18:05 #228356
I did not miss that, i just do not care, it works and i still have it in use on some machines, it just never fails.
Same for Wheezy, if it works, why change ?
Also no need to change the parallel port, it works!
In case you go the changing route, there are parallel port addon cards, there are Mesa boards for PCI, PCI-E and ETH, all can do 2 parallel ports, but at much, much higher speeds, and can do other stuff also, like hardware PWM, encoder counting, etc.
Time to create page: 0.201 seconds
