Partition
15 Dec 2021 10:46 #229109 by Temo
Partition was created by Temo
Hello
I wonder if one can partition a 32GB microSd memory card and then install two different versions of Linux on a raspberry pi4?
If so, how would one go around making a bootloader where you choose what version to load, if not you could use the second partition to store your user files. It just seems cutch a waste of space when you know how little space LinuxCNC uses, and if you buy a smaller card the speeds goes down.
Terje
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
15 Dec 2021 11:13 #229112 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Partition
Maybe something like this is what you are after ?
www.makeuseof.com/tag/how-to-install-mul...rd-for-raspberry-pi/
Considering the price of SD cards I just swap them out, not that often mind.
  • Moderator
  • Moderator
15 Dec 2021 12:26 #229119 by tommylight
Replied by tommylight on topic Partition
Rob, welcome back! :)
15 Dec 2021 12:29 #229120 by Clive S
Replied by Clive S on topic Partition
Is this the Rob I think it is, if so big welcome back
  • Moderator
  • Moderator
15 Dec 2021 12:35 #229121 by tommylight
[/quote]
I would not bet my life on it, but the nickname makes me think he is.
15 Dec 2021 13:04 #229125 by Temo
Replied by Temo on topic Partition
Yes you're probably right, they don't cost a fortune now days.
I see many varn against using a Pi for the LinuxCnc as they don't think it's up to the task, what are your experience with the Pi4, and what controller cards are you using between the Pi4 and the router. I haven't bought any cards yet, but will need to control 3 axis with stepper motors and one spindle.
One last question: is there a "GoTo" small form factor pc, with or without parallel port that are especially recommended/suited for the LinuxCnc and a router build. I'm thinking of buying the Sorotec compact line, but they don't have any option for LinuxCnc, only for Mach3/4 and EdingCnc.
Terje
  • Moderator
  • Moderator
15 Dec 2021 13:13 #229126 by tommylight
From what i've read here, RPI4 is good enough to run a machine, but i would suspect anything 3D/CAM will bring it to it's knees.
Even RPI3 is usable for just running the machine and a bit of 2D / Inkscape, but using bigger files will slow it down significantly. Still, the machine runs properly despite slow downs.
For use with RPI4, Mesa 7i92, 7i96, 7i76E, 7i95, 7i97, 7i80, etc. can be used, but for a beginner 7i96 and 7i76E are perfect.
15 Dec 2021 14:35 #229132 by Temo
It will only be used to run the machine, no cam. I guess the 7i96 and 7i76E comes at a cost to, so how does this compare to buying and using a small form factor PC?
  • Moderator
  • Moderator
15 Dec 2021 16:47 #229145 by tommylight
HP 8300 SFF works perfectly well for everything, used i can get them for 80-100 Euro here. I have 3 of them in daily use, next week getting another 3.
15 Dec 2021 20:13 #229158 by Temo
Thanks, so you prefer one without a parallel port, do you then buy a pcie parallel adapter to put in the cabinet, or do you solely rely on the mesa cards to run out of usb/ethernet?
Time to create page: 1.157 seconds
