Partition
- elf
- Thank you received: 14
15 Dec 2021 20:20 #229159
by elf
Replied by elf on topic Partition
Definitely do not get this one: www.amazon.com/dp/B07QY8LDGX There are other NUCs which install LinuxCNC better.
- ALittleOffTheRails
- Visitor
15 Dec 2021 20:58 - 15 Dec 2021 21:03 #229161
by ALittleOffTheRails
The Mesa ethernet cards have to connected to a on board ethernet port or a PCI\PCIe ethernet card. USB ethernet dongles are not the ones to be used, due to USB not having a realtime implementation.
I have a M4A785D-M_PRO motherboard with an old X2 Athlon II @ 3.0GHz (from memory it will support Phenom II / Athlon II / Phenom / Athlon) with 4GB ram combined with a AMD GPU will give very very good latency when booted with isolcpus=1, haven't a Quad core CPU to test with. Yep it's about 13 yro but still works well. This is with the recent Buster iso with a RT-PREEMPT kernel, not a RTAI kernel.
Replied by ALittleOffTheRails on topic Partition
Thanks, so you prefer one without a parallel port, do you then buy a pcie parallel adapter to put in the cabinet, or do you solely rely on the mesa cards to run out of usb/ethernet?
Last edit: 15 Dec 2021 21:03 by ALittleOffTheRails.
- Thank you received: 7468
15 Dec 2021 22:26 #229169
Replied by tommylight on topic Partition
Yes i do prefer without parallel port whenever i can manage to get the Mesa boards, otherwise i still use parallel ports on a lot of machines and i still have some add on parallel port cards.Thanks, so you prefer one without a parallel port, do you then buy a pcie parallel adapter to put in the cabinet, or do you solely rely on the mesa cards to run out of usb/ethernet?
- Temo
16 Dec 2021 23:01 #229215
by Temo
Replied by Temo on topic Partition
Thank you all!
I just have more more question: since it's not so easy here to find these old desktops, what would be the prefered new itx-motherboard, barebone, nuc, off the shelf small form factor PC or desktop PC of 2021?
16 Dec 2021 23:49 #229219
The only ITX i have is the daily driver on my desk, it has very good latency, but it also has a eye watering price tag.
From experience, new boards are a cr@p shoot, had a better/higher priced board that was terrible for latency, this one is perfect, my bro had a cheaper one that was also very good as far as latency it concerned.
All AMD, B550 and X570.
I still have a stinking suspicion it also has to do with processors but could not verify, this is what i got from short tests:
bad latency = Ryzen 5 3500X
good latency, Ryzen 5 3600, Ryzen 7 3700X, Ryzen 9 3900X
The suspicious part? 3500X has no hyperthreading, all the others do, and on Intel systems the first thing to turn off is hyperthreading!
- Clive S
- Thank you received: 486
17 Dec 2021 11:02 #229281
by Clive S
Is this the type of pc you use HP Elite 8300 SFF PC - i3-3220 @3.30GHz, 4GB, 500GB HDD
I have seen them for £40 on ebay inc del.
Replied by Clive S on topic Partition
HP 8300 SFF works perfectly well for everything, used i can get them for 80-100 Euro here. I have 3 of them in daily use, next week getting another 3.
17 Dec 2021 14:29 #229294
Mine are 4 core i5, fourth gen.
- seuchato
- Thank you received: 126
02 Jan 2022 02:22 #230519
by seuchato
Replied by seuchato on topic Partition
Tommy
Youa are sure about "fourth gen"? I have a few 8300sff and towers. These ar ALL 3rd Gen, ie: i7 3770.
Greez
Chris
Greez
Chris
02 Jan 2022 02:54 #230521
Not really, i have to many PC's to keep track with, so i do not bother much !Tommy
Greez
Chris
Time to create page: 0.532 seconds
