Parallel port controller issues, can not find address
- Jake
- Thank you received: 10
22 Dec 2021 01:25 - 22 Dec 2021 01:53 #229684
by Jake
Replied by Jake on topic Parallel port controller issues, can not find address
Well I am not sure what I changed this time other than a reboot and using "0xe010"
I do get a different error message, the parallel port is seeing the PPMC cards. I am still getting a startup error, and still states there is not a parallel port registered at that address.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/hurco/linuxcnc/configs/by_interface.pico.ppmc_vel'
Machine configuration file is 'ppmc.ini'
INIFILE=/home/hurco/linuxcnc/configs/by_interface.pico.ppmc_vel/ppmc.ini
VERSION=1.1
PARAMETER_FILE=ppmc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./ppmc_load.hal
Found file(REL): ./ppmc_servo.hal
Found file(REL): ./ppmc_motion.hal
Found file(REL): ./ppmc_io.hal
Found file(REL): ./vc-p4s.hal
Starting DISPLAY program: axis
No parport registered at 0xe010. This is not always an error. Continuing.
emc/task/emctask.cc 411: interp_error: Parameter file name is missing
emc/task/emctaskmain.cc 3087: can't initialize interpreter
No option 'tto_g11' in section: 'DEFAULT'
No option 'show_program' in section: 'DEFAULT'
No option 'show_rapids' in section: 'DEFAULT'
No option 'program_alpha' in section: 'DEFAULT'
No option 'show_live_plot' in section: 'DEFAULT'
No option 'show_tool' in section: 'DEFAULT'
No option 'show_extents' in section: 'DEFAULT'
No option 'show_offsets' in section: 'DEFAULT'
No option 'grid_size' in section: 'DEFAULT'
No option 'show_machine_limits' in section: 'DEFAULT'
No option 'show_machine_speed' in section: 'DEFAULT'
No option 'show_distance_to_go' in section: 'DEFAULT'
No option 'dro_large_font' in section: 'DEFAULT'
No option 'block_delete' in section: 'DEFAULT'
No option 'optional_stop' in section: 'DEFAULT'
No option 'recentfiles' in section: 'DEFAULT'
waiting for s.joints<0>, s.kinematics_type<0>
Debug file information:
Note: Using POSIX realtime
PPMC: bus 0 epp_dir = 1
PPMC: bus 1 epp_dir = 0
PPMC: bus 2 epp_dir = 0
PPMC: checking EPP bus 0 at port E010
PPMC: slot 0: ID code: 15 PPMC encoder card 0
PPMC: exporting encoder timestamp pins
PPMC: exporting encoder pins / params
read cache bitmap: 03ff1fff
write cache bitmap: 00002000
PPMC: slot 2: nothing detected at addr 2 reads 2f
PPMC: slot 3: nothing detected at addr 3 reads 3f
PPMC: slot 4: ID code: 23 PPMC DAC card
PPMC: exporting PPMC DAC
read cache bitmap: 00000000
write cache bitmap: 000000ff
PPMC: slot 5: nothing detected at addr 5 reads 5f
PPMC: slot 6: ID code: 34 PPMC Digital I/O card
PPMC: exporting PPMC digital inputs
PPMC: exporting as MASTER D In
PPMC: exporting PPMC digital outputs
PPMC: master DIO at # 8
PPMC: exporting as MASTER D Out
read cache bitmap: 00000007
write cache bitmap: 00000007
PPMC: slot 7: ID code: 34 PPMC Digital I/O card
PPMC: exporting as SLAVE D In
PPMC: slave DIO addr 72
PPMC: slave DIO # 8
PPMC: exporting as SLAVE D Out
read cache bitmap: 00000003
write cache bitmap: 00000001
PPMC: slot 8: nothing detected at addr 8 reads 8f
PPMC: slot 9: nothing detected at addr 9 reads 9f
PPMC: slot 10: nothing detected at addr a reads af
PPMC: slot 11: nothing detected at addr b reads bf
PPMC: slot 12: nothing detected at addr c reads cf
PPMC: slot 13: nothing detected at addr d reads df
PPMC: slot 14: nothing detected at addr e reads ef
PPMC: slot 15: nothing detected at addr f reads ff
PPMC: bus 0 complete
EMERGENCY STOP
SPINDLE FAULT
LOW AIR PRESSURE
SERVO FAULT
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
cant resolve path to '/home/jake/linuxcnc/configs/by_interface.pico.ppmc_vel/python/toplevel.py'
Interp ctor: cant instantiate Python plugin
Python plugin configure() failed, status = -5
Python plugin required for prolog=, but not available: 70:REMAP = M6 modalgroup=8 prolog=change_prolog ngc=toolchange epilog=change_epilog
Python plugin required for epilog=, but not available: 70:REMAP = M6 modalgroup=8 prolog=change_prolog ngc=toolchange epilog=change_epilog
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.150 units/sec 9.000 units/min
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
1620
Stopping realtime threads
Unloading hal components
PPMC: shutting down
Last edit: 22 Dec 2021 01:53 by Jake.
- ALittleOffTheRails
- Visitor
22 Dec 2021 01:59 - 22 Dec 2021 01:59 #229686
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Parallel port controller issues, can not find address
Try this one
Anyways there is a ini isssue. Can you post your hal, ini & any other files needed to run this config.
sudo lspci -vnAnyways there is a ini isssue. Can you post your hal, ini & any other files needed to run this config.
Last edit: 22 Dec 2021 01:59 by ALittleOffTheRails.
- Jake
22 Dec 2021 02:08 #229687
by Jake
When I went to the 2.8x It ran a script to updsate the /.ini file. It seems as now that some of the changes that may have been made have made it angry. I wonder if it will run if I just load my old .ini up.....
- Jake
22 Dec 2021 02:09 #229688
by Jake
sudo lspci -vn
04:00.0 0701: 9710:9900 (prog-if 03 [IEEE1284])
Subsystem: a000:2000
Flags: bus master, fast devsel, latency 0, IRQ 11
I/O ports at e010
I/O ports at e000
Memory at f7c01000 (32-bit, non-prefetchable) [size=4K]
Memory at f7c00000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [800] Advanced Error Reporting
I/O ports at e010
I/O ports at e000
- Thank you received: 7468
22 Dec 2021 02:54 #229691
Replied by tommylight on topic Parallel port controller issues, can not find address
Forget that, it is finding PPMC, so that is good.
The issues are with missing python stuff used in remap.
The following user(s) said Thank You: Jake
- Jake
22 Dec 2021 03:05 #229692
by Jake
I just wish I knew what one thing got it to that point. I'll start digging through the files in the morning to see what Python pieces are missing.
Thanks again everyone!
- Visitor
22 Dec 2021 03:07 #229693
Can you reboot & try
If you haven't any modules blacklisted parport_pc should load.
sudo dmesg | grep -i parportsudo ls /dev/par*lsmodIf you haven't any modules blacklisted parport_pc should load.
- Thank you received: 1472
22 Dec 2021 14:30 #229730
Replied by Todd Zuercher on topic Parallel port controller issues, can not find address
Does this file "/home/jake/linuxcnc/configs/by_interface.pico.ppmc_vel/python/toplevel.py" exist in it's specified location?
- Jake
22 Dec 2021 16:39 - 22 Dec 2021 17:17 #229744
by Jake
I was able to get it to start after fixing spindle.xml which the upgrade script had blanked the file out. The latency is pretty high, even after cranking servo period to 5,000,000 its still not real happy. Looks like with the later RTAI there is no more ISOCPUS to be done. I am getting an "unexpected real time delay on task 0 with period 5000000"
There is a pop up box that it is not happy with axis.ngc. Is there a way to get LCNC to start without opening this axis.ngc file ?
" near line 0 of /usr/share/axis/images/axis.ngc: exception during generator call: Type error: 'nonetype' object not callable
I am still getting the error that "no paraport is registered at 0xe010"
so I have some more items to work through. At least it is starting at the moment, making progress. Huge thanks to of of you for getting me running again.
Thanks Todd !! that was one of the problems, on to the next one.... With the script running it puts the python address all the way at the bottom of the file.Does this file "/home/jake/linuxcnc/configs/by_interface.pico.ppmc_vel/python/toplevel.py" exist in it's specified location?
Last edit: 22 Dec 2021 17:17 by Jake.
- Jake
22 Dec 2021 19:03 #229753
by Jake
changing the "return" to "yield" in stdglue.py fixed the initial pop up box. Now the graphics in axis function. I would load another .ngc file and would have no graphics of the tool path. That is solved.
I have gone through and eliminated all the viturization and power management in the bios. The latency is still high. Jitter really only gets up to 15000, the max interval servo will got over the 5m and get the latency message.
Time to create page: 0.664 seconds
