Parallel port controller issues, can not find address
- Thank you received: 7479
22 Dec 2021 22:35 #229771
Replied by tommylight on topic Parallel port controller issues, can not find address
Disable hyperthreading, speedstep, virtualisation, modem, serial ports, turbo.
- Jake
- Thank you received: 10
22 Dec 2021 23:59 #229778
by Jake
Replied by Jake on topic Parallel port controller issues, can not find address
Thanks Tommy,
I had most of that turned off. Turned the rest of it off.
Max interval stayed 1m jitter improved its about 10k.
I can move slowly jog the X and Y, the Z is not happy now. If the speeds are increased it stops on a following error. Then it stutters after a restart like the PID tuning is off.
Ill hopefully be back at it in the morning, along with trying to get the Vista pendant to work again.
- ALittleOffTheRails
- Visitor
23 Dec 2021 00:11 #229779
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Parallel port controller issues, can not find address
You can try this as well via editing the grub command line when you boot.
For a 4 core processor
For 2 core processor
To make it permanent editas superuser with whatever option works
runas superuser
then reboot
isolcpus=1,2,3 intel_idle.max_cstate=0 processor.max_cstate=0 idle=pollFor 2 core processor
isolcpus=1 intel_idle.max_cstate=0 processor.max_cstate=0 idle=pollTo make it permanent edit
/etc/default/grubrun
update-grubthen reboot
- Jake
24 Dec 2021 02:43 #229849
by Jake
I am getting permission denied when I try to make the edit permanent. I am logged in as root. I have had enough of it today. I will try again tomorrow.
root@hurco:~# /etc/default/grub
bash: /etc/default/grub: Permission denied
- Visitor
24 Dec 2021 03:39 #229856
That was the path to the file you were meant to edit, not the command. You need to use your preferred editor to edit the file.
The system thought you wanted to execute that file.
- Jake
24 Dec 2021 03:41 #229857
by Jake
Thanks! I was not thinking clearly earlier.
- Visitor
24 Dec 2021 03:53 #229860
It's that time of year hahaha
- Jake
24 Dec 2021 16:09 - 24 Dec 2021 16:10 #229900
by Jake
I wish I had a good excuse for having my head up my.....
Having a small window of time to try and run out here and get something done is a challenge. Especially with a constant distraction in the shop.
I did the first check of ISOLCPU with 1,2,3 and it knocked the base thread to 35k, the servo is still at 1M
Ill keep working on it...Thanks again!
I need to look up on how to get rid of the screen lock also. I tried one thing and that was unsucessful, I just want screen saver after like 30 minutes and NO lock.
Last edit: 24 Dec 2021 16:10 by Jake.
- Jake
02 Jan 2022 16:32 #230557
by Jake
A kinda update..... In all of the work to attempt to get the machine to function, I was successful at getting Buster to lock up every time I would launch LCNC. Seems like this really started after adding the xscreensaver to disable the screen lock. I just started over. I have all the items that were discussed through the thread resolved and am getting a no start. I try the below commands, first one I get a new line, second one it states there is no such file or directory. I looked in /dev/ and its not there. I am trying to back track to see what I missed to get that created. Any suggestions ?
Thanks! Happy New Year to everyone!
Can you reboot & try
[/code][/code]sudo dmesg | grep -i parport [code]sudo ls /dev/par* [code]lsmod If you haven't any modules blacklisted parport_pc should load.
- Visitor
02 Jan 2022 22:42 #230583
What output is Linuxcnc giving when it fails to start ?
What is the output of the following ?
So we can safely assume that the parallel port is coming up in the lspci command ?
ls /etc/modprobe.d/So we can safely assume that the parallel port is coming up in the lspci command ?
Time to create page: 0.286 seconds
