19 Network Manager Icons!
  • PhilCNC
  • PhilCNC's Avatar Topic Author
  • Senior Member
  • Senior Member
29 Dec 2021 23:03 #230296 by PhilCNC
19 Network Manager Icons! was created by PhilCNC
There are 19 network manager icons at the top of my screen! When I disconnect from a network, half my screen is covered by 19 different "network disconnected notifications. What can I do to fix this?
29 Dec 2021 23:29 - 29 Dec 2021 23:31 #230298 by 0x2102
Replied by 0x2102 on topic 19 Network Manager Icons!
You can try this or just remove it after you are done with your network config.
forum.linuxcnc.org/38-general-linuxcnc-q...little-issues#226480
Last edit: 29 Dec 2021 23:31 by 0x2102.
The following user(s) said Thank You: AgentWD40
  • PhilCNC
  • Senior Member
  • Senior Member
29 Dec 2021 23:53 #230301 by PhilCNC
Replied by PhilCNC on topic 19 Network Manager Icons!
Hey this is exactly what I needed! Thanks for making this solution fast and easy!
29 Dec 2021 23:57 #230302 by AgentWD40
Replied by AgentWD40 on topic 19 Network Manager Icons!
I was wondering what was going on, I was only up to 5 icons though :)
01 Jan 2022 09:54 #230440 by hitchhiker
Replied by hitchhiker on topic 19 Network Manager Icons!
i had the same problem eith wifi... then i close all n trays and when i shut down or reboot i uncheck the save session option.
works perfect
Time to create page: 0.373 seconds
