No steps Mesa 7i76e
03 Jan 2022 23:55 #230696 by PCW
Replied by PCW on topic No steps Mesa 7i76e
By static voltage I mean what is read by a voltmeter
when LinuxCNC is not running
04 Jan 2022 22:58 #230803 by ggsxx
Replied by ggsxx on topic No steps Mesa 7i76e
Between pin 1 and 6 Ground and 5v+ i have 5.02v. 2-3 Step+ and Step- 0v, 3-4 Dir- Dir+0v. I also did a voltage drop from pin 6-5 5.02v, 6-4 4.58v, 6-3 5.02v and 4,63v.
04 Jan 2022 23:35 - 04 Jan 2022 23:36 #230809 by PCW
If you have 0V between Step+ and Step- or Dir+ and Dir-, this means that
one or both of the Step/Dir output driver chips have been damaged.
Last edit: 04 Jan 2022 23:36 by PCW.
05 Jan 2022 01:09 #230818 by ggsxx
How much static voltage should i have been able to get ?
Are those the two chips in front of the TB2 connectors?
05 Jan 2022 02:11 #230820 by PCW
Without load you should always get +5V or -5V from DIR+ to DIR- and STEP+ to STEP-
(5V or -5V depending on the output state, STEP+ and DIR+ should always be the logical inverse of STEP- and DIR-)
The driver chips are a 74ACT540 (U12) and a 74ACT541 (U19)
05 Jan 2022 03:29 #230823 by ggsxx
I have to admit that i over powered the P3 connector by putting the terminal of the positive on the 12 volts instead of the 5 volts. Dumb mistake.
I was hoping for the best since nothing was connected to it and no other components show any traces of damage. So these are the octal buffers that create the step/dir signals or act more like the ones in a computer clocking the bits?
05 Jan 2022 23:05 #230907 by ggsxx
Thanks you have been very helpfull. I realy appreciate the time you spent helping me. You seem to know a lot about these cards.What do you do for a living?
05 Jan 2022 23:17 #230909 by Clive S
Replied by Clive S on topic No steps Mesa 7i76e
PCW = Peter owns Mesa so you can't get better that that. The best and quickest help you can fine.
06 Jan 2022 00:01 #230911 by PCW
"So these are the octal buffers that create the step/dir signals or act more like the ones in a computer clocking the bits? "
They are just level shifters from the 3.3V outputs of the FPGA to 24 mA 5V outputs to interface with the step/dir drives.
The following user(s) said Thank You: ggsxx
06 Jan 2022 00:40 #230914 by ggsxx
Can i get an estimate to get it fixed?
Time to create page: 0.137 seconds
