Probe tripped during non-probe move
- spangledboy
- Thank you received: 10
13 Jan 2022 21:35 #231710
by spangledboy
Probe tripped during non-probe move was created by spangledboy
I fairly recently upgraded to v2.8.2 and I use Gmoccapy with a tool length sensor which uses the probe pin to measure tool length.
I've recently noticed that the probe pin now appears to be monitored at all times, so if my mill vibrates a bit too much, it stops the machine with the "Probe tripped during non-probe move" message - in fact this evening it even triggered it during the too length measuring process. This seems to be happening a lot, making it difficult to machine anything. I assume that this is a feature of the newer release as this never used to happen on the older version.
Is there some way to disable this monitoring of the probe pin? I'm sure it's valuable when using a probe, but for tool length measurement I only want the machine to pay attention to it when measuring a tool.
- Thank you received: 7488
15 Jan 2022 07:57 #231869
Replied by tommylight on topic Probe tripped during non-probe move
There are ways of disabling it and having it enabled only during probing, but it is better to find why it is triggering, and that would most probably be interference.
First thing is to use a shielded cable for the probe and attach the shield to ground only on the electronics side.
Also using ferite beads on spindle motor wires helps a lot.
- spangledboy
16 Jan 2022 11:06 #232003
by spangledboy
Replied by spangledboy on topic Probe tripped during non-probe move
I know why it's tripping - it's due to the vibration/movement of the mill when it starts off, as the tool length measurement device (actually a re-purposed probe) is mounted on the table.
I suspect that the contacts may need cleaning in the probe, as it's been reliable for several years on the previous LinuxCNC release, so if the previous releases also checked for the probe being tripped, it may just be a coincidence that this started following the recent software upgrade.
- spangledboy
17 Jan 2022 13:49 #232118
by spangledboy
I think I've resolved the issue now - I had another probe available which takes a deal more force to trigger, so I made up a mount for that and tested it with a positive outcome.
No unwanted probe trips yesterday and it triggers repeatably to within 0.01mm.
17 Jan 2022 15:12 #232126
Nice.
The following user(s) said Thank You: spangledboy
- natholego11
- Thank you received: 4
09 Feb 2022 02:24 #234371
by natholego11
Replied by natholego11 on topic Probe tripped during non-probe move
Tommy,
you mentioned there are ways to disable the probe and only have it on during probing moves.
I have one of these: link
and ive noticed a similar condition as explained above. when I do manual movements on the machine (just facing parts off and what not) and there is excessive chatter or the feeds/speeds are not perfect. I get the same error message.
Is there a way to switch off the probe pin until its only running a probe macro?
09 Feb 2022 13:24 #234393
In hal add an AND component and wire it so the output is only active while the probe is on.
- natholego11
09 Feb 2022 21:36 #234432
by natholego11
haha, i am not following you at all. the probe is wired into my 7i96 I dont have any kind of intermediate switch that turns the probe on or off.
09 Feb 2022 23:06 #234441
I think i did say in .hal, wiring stuff is also done in hal for LinuxCNC.
Leme see if i can find it, i am sure there is another topic here on this forum with the same subject...
- natholego11
16 Feb 2022 15:13 #235044
by natholego11
Any luck finding it?
Time to create page: 0.158 seconds
