Probe tripped during non-probe move
16 Feb 2022 16:01 #235046 by tommylight
Replied by tommylight on topic Probe tripped during non-probe move
Nope, i would have posted it if i did, but my search-fu is failing me lately. :(
17 Feb 2022 11:43 #235121 by rodw
Replied by rodw on topic Probe tripped during non-probe move
a no wiring solution is to and.2 the probe input with a digital input and in your gcode probing routine issue a M67 or M68 command to turn the input on and off. simple and effective.
18 Feb 2022 12:56 #235233 by natholego11
Replied by natholego11 on topic Probe tripped during non-probe move
so... it would look something like this:
loadrt probeon output_type=0
Addf and2.0 servo-thread
addf probeon.update servo-thread
setp probeon.0.enable TRUE
# ---probe signal---
net probe-in => motion.probe-input
but now im stuck, how do I link the M68 E0 Q1 to the probe?
18 May 2022 17:57 #243287 by zu4lu
21 Jul 2022 16:40 #247960 by tightmopedman9
Replied by tightmopedman9 on topic Probe tripped during non-probe move
I have the same tool length sensor that was linked earlier in this thread. I haven't had any problems with it triggering during cutting, but I did have an issue with the probe triggering after retraction, if I had the spindle spinning during probing. For larger diameter tools I get more accurate touch results if I spin the spindle slowly while touching off the tool, so I wanted to retain this feature.
Here is my HAL, which also ands two inputs, one for the tool setter and one for the touch probe.
net M64-and-in                  motion.digital-out-00                 and2.13.in0
net tool-sensor-and-in       hm2_5i25.0.7i77.0.0.input-16   and2.13.in1
net tool-sensor                  and2.13.out                                or2.1.in0
net probe-sensor               hm2_5i25.0.7i77.0.0.input-00    or2.1.in1
net probe-or-tool-sensor    or2.1.out
net probe-or-tool-sensor    motion.probe-input
I wrapped any G38 moves in the tool touch off subroutine with:
M64 P00
(G38)
M65 P00
The default state of motion.digital-out-00 is 0, so this code will also prevent the tool touch probe from triggering outside of a tool touch routine.
Time to create page: 0.149 seconds
