- LinuxCNC
- General LinuxCNC Questions
- How to change the direction of the X and Y axes in Linuxcnc by changing entries
- jarcysgru
- Thank you received: 6
17 Jan 2022 17:50 #232142
by jarcysgru
How to change the direction of the X and Y axes in Linuxcnc by changing entries was created by jarcysgru
How can I change the directions of the X and Y axes in a Hal file so that I don't have to run my Stepconf Wizard setup to overwrite the files.
There is a mention here, but it is not enough for me
odwrocenie-kierunku-osi-w-emc2-t35039.html
Here is my Hal file
# Generated by stepconf 1.1 at Fri Apr 3 19:32:57 2020
# Jeśli zmodyfikujesz ten plik zmainy zostaną
# nadpisane gdy uruchomisz ponownie Stepconf
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0x378 out"
setp parport.0.reset-time 2000
loadrt stepgen step_type=0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net coolant-flood <= iocontrol.0.coolant-flood
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
setp parport.0.pin-04-out-invert 1
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
setp parport.0.pin-06-out-invert 1
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
setp parport.0.pin-07-out-invert 1
net zdir => parport.0.pin-07-out
net xenable => parport.0.pin-17-out
net estop-ext <= parport.0.pin-10-in
net home-x <= parport.0.pin-11-in-not
net home-y <= parport.0.pin-12-in-not
net home-z <= parport.0.pin-13-in-not
net probe-in <= parport.0.pin-15-in
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 95000
setp stepgen.0.dirsetup 95000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net home-x => joint.0.home-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 95000
setp stepgen.1.dirsetup 95000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net home-y => joint.1.home-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 95000
setp stepgen.2.dirsetup 95000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp parport.0.pin-16-out-invert 1
net coolant-flood => parport.0.pin-16-out
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net home-z => joint.2.home-sw-in
net estop-ext => iocontrol.0.emc-enable-in
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
Here is my Hal file
- Online
- Thank you received: 7468
17 Jan 2022 18:50 - 17 Jan 2022 18:51 #232158
Replied by tommylight on topic How to change the direction of the X and Y axes in Linuxcnc by changing entries
Add or remove:
setp parport.0.pin-03-out-invert TRUE
setp parport.0.pin-05-out-invert TRUE
Last edit: 17 Jan 2022 18:51 by tommylight.
The following user(s) said Thank You: jarcysgru
- jarcysgru
18 Jan 2022 17:18 #232299
by jarcysgru
Replied by jarcysgru on topic How to change the direction of the X and Y axes in Linuxcnc by changing entries
I changed the directions of the X and Y axes, now I have a problem with the stopwatches based on them, I don't know what the problem is, how can I do it.
- jarcysgru
18 Jan 2022 17:23 #232300
by jarcysgru
I have changed the directions of the X and Y axes now I have a problem with homing limit switches, which means they do not rely on what the problem is, how to do it
- Thank you received: 2164
18 Jan 2022 18:57 #232314
Replied by Aciera on topic How to change the direction of the X and Y axes in Linuxcnc by changing entries
If you change the direction of your motors then you will have to reconfigure your limit/home switches because now you have also swapped the positive and negative ends of the axis.
I only see home switches in your config so you probably need to change the homing direction in the ini file and you will also need to change the joint and axis limits set there.
If unsure please post your .ini file
- jarcysgru
18 Jan 2022 20:01 #232325
by jarcysgru
# Generated by stepconf 1.1 at Sun Feb 9 16:54:21 2020
[EMC]
MACHINE = huanyang
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MIN_FEED_OVERRIDE = 0.000000
MAX_FEED_OVERRIDE = 1.200000
MAX_SPINDLE_OVERRIDE = 1.5
MIN_SPINDLE_OVERRIDE = 0.1
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 83.3333
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
PYVCP = custompanel.xml
TKPKG = Ngcgui 1.0
NGCGUI_FONT = Helvetica -12 normal
NGCGUI_PREAMBLE = mm_std.ngc
NGCGUI_SUBFILE = kanalek.ngc
NGCGUI_SUBFILE = kanalek_y.ngc
NGCGUI_SUBFILE = otwor.ngc
NGCGUI_SUBFILE = otwory_po_okregu.ngc
NGCGUI_SUBFILE = przejazd.ngc
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = ../../nc_files/ngcgui_lib:../../ngcgui_lib/utilitysubs:/home/j/linuxcnc/nc_files/ngcgui
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 39062
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = huanyang.hal
HALFILE = custom.hal
HALFILE = xhc-whb04b-6.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
MDI_COMMAND=(debug,00)
MDI_COMMAND=(debug,macro1)
MDI_COMMAND=(debug,macro2)
MDI_COMMAND=(debug,macro3)
MDI_COMMAND=(debug,macro4)
MDI_COMMAND=G1 G53 X0 Y0 Z0 F4000
MDI_COMMAND=(debug,macro6)
MDI_COMMAND=G1 X0 Y0 Z0 F4000
MDI_COMMAND=(debug,macro8)
MDI_COMMAND=(debug,macro9)
MDI_COMMAND=(debug,macro10)
MDI_COMMAND=(debug,macro11)
MDI_COMMAND=(debug,macro12)
MDI_COMMAND=(debug,macro13)
MDI_COMMAND=(debug,macro14)
MDI_COMMAND=(debug,macro15)
MDI_COMMAND=(debug,macro16)
MDI_COMMAND=G1 G53 Z0 F4000
MDI_COMMAND=(debug,macro17)
MDI_COMMAND=(debug,macro18)
MDI_COMMAND=(debug,macro19)
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 8.00
MAX_LINEAR_VELOCITY = 80.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 76.0009728125
MAX_ACCELERATION = 500.0
MIN_LIMIT = -460.0
MAX_LIMIT = 0.001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -460.0
MAX_LIMIT = 0.001
STEPGEN_MAXACCEL = 625.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 1.500000
HOME_LATCH_VEL = 1.500000
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 70.0
MIN_LIMIT = -510.0
MAX_LIMIT = 0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -510.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 70.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 60.0
MIN_LIMIT = -190.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -190.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 60.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 0
[EMC]
MACHINE = huanyang
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
INTRO_TIME = 5
EDITOR = gedit
GEOMETRY = xyz
TKPKG = Ngcgui 1.0
[KINS]
JOINTS = 3
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 39062
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_X]
MIN_LIMIT = -460.0
MAX_LIMIT = 0.001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -460.0
MAX_LIMIT = 0.001
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 70.0
MIN_LIMIT = -510.0
MAX_LIMIT = 0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -510.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 70.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 60.0
MIN_LIMIT = -190.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -190.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 60.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 0
19 Jan 2022 08:34 - 19 Jan 2022 08:35 #232413
Presuming that, after changing motor direction in X and Y, the machine now moves in the wrong direction during the homing process you can try these settings:
[AXIS_X]
MAX_LIMIT = 460.0
MIN_LIMIT = -0.001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MAX_LIMIT = 460.0
MIN_LIMIT = -0.001
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_SEARCH_VEL = -1.500000
HOME_LATCH_VEL = -1.500000
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 70.0
MAX_LIMIT = 510.0
MIN_LIMIT = -0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MAX_LIMIT = 510.0
MIN_LIMIT = -0.001
MAX_VELOCITY = 70.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
[AXIS_X]
MAX_LIMIT = 460.0
MIN_LIMIT = -0.001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MAX_LIMIT = 460.0
MIN_LIMIT = -0.001
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 70.0
MAX_LIMIT = 510.0
MIN_LIMIT = -0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MAX_LIMIT = 510.0
MIN_LIMIT = -0.001
MAX_VELOCITY = 70.0
SCALE = 320.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
Last edit: 19 Jan 2022 08:35 by Aciera.
- jarcysgru
19 Jan 2022 17:39 #232453
by jarcysgru
Dziekuje Aciera i tommylight bardzo za pomoc , teraz wszystkie osie działają tak jak chciałem .
Pozdrawiam i życzę wszystkiego dobrego.
- Online
19 Jan 2022 17:46 #232455
I can not recall how to say "you are welcomed" in Polish !
19 Jan 2022 17:52 #232456
Nie ma za co!
- LinuxCNC
Time to create page: 0.341 seconds
