YASKAWA SERVOPACK Speed-Control instead Postion Control
02 Mar 2022 17:15 #236198 by nighteagle
@ehb
So do you know your encoder is 12-Bit or 15-Bit on the Yaskawa Output?
I think is 12-Bit?
02 Mar 2022 23:57 #236232 by andypugh
Because what means right Hand position in the text?
With the board oriented as shown, with the screen print on the board the conventional way round for reading it.
Jumper to the right means that the jumper is closer to your right hand. Jumper to the left means closer to your left hand.
I suspect that this is some unexpected language issue?
03 Mar 2022 06:07 - 03 Mar 2022 06:26 #236244 by ehb
Hi nighteagle,
sorry for not chiming in lately.
I've wired up the drives now and left all encoder jumpers on the 7i77 in stock position. Didn't change a thing and it all works very nicely!
I will get back to you once I checked what I entered in pncconf. I think it was 4000 pulses per revolution plus the ratios of belt and spindle that made me come up with an ENCODER_SCALE (in .ini file) of about 640.
Last edit: 03 Mar 2022 06:26 by ehb.
03 Mar 2022 06:34 #236245 by ehb
If you want, you can post an email address and I'll send you my phone number. We could talk it through (in german :) ) while both being in front of the machines.
03 Mar 2022 08:36 - 03 Mar 2022 08:42 #236247 by nighteagle
@ehb
My machine have direct-drive the axis - it is a satellite-spindel system.
Yesterday evening i have test over mesa and after F1 i have press F2 to acticate the yaskawas and i have an error on one of it - it is a problem of one of the servos - last week i have changed the ic's of the encoder because it looks like a encoder problem - but then i have replace the encoder with one of the other working motors - and have the same error "C" it can be the motor itself - but i measure all is okay - so i think some problems with cable.. but all looks okay - i have to check where the problem is. My last week was an Ghost-Buster week - i thought it was encoder but not - it was an error-ghost. One week lifetime gone...
But what i see is linuxcnc shows me error on joint 1 and the error is on x-axis that mean joint 0 - so looks like something is wrong in ini or hal-file. Connection on MESA is correct...
Last edit: 03 Mar 2022 08:42 by nighteagle.
03 Mar 2022 08:40 #236248 by nighteagle
@andypugh
Thanks for the explanation -
I suspect it is a bad datasheet - no one use this terms to give information of jumper-configuration. Normaly you have a logic-table for such settings.
Also the Pin 1 of each of the TB1-5 is on the opposite so this all is confusing . and the drawing in the datasheet is so bad quality... but okay...this is all offtopic.
So if i'm right if the Jumper configuration is like the image from the datasheet then the Encoder are set to Diffential-Mode?
Time to create page: 0.120 seconds
