LinuxCNC Paid Help
27 Jan 2022 23:05 - 28 Jan 2022 00:39 #233325 by smc.collins
Replied by smc.collins on topic LinuxCNC Paid Help
except that the error only occurs on my machine, but not the backplot Axis sim
File Name: HurcoKM3.hal
File Size:11 KB
File Name: HurcoKM3.ini
File Size:4 KB
Last edit: 28 Jan 2022 00:39 by smc.collins.
28 Jan 2022 02:18 #233335 by cakeslob
Replied by cakeslob on topic LinuxCNC Paid Help
linuxcnc.org/docs/devel/html/config/ini-...l#gcode:ini-features
CENTER_ARC_RADIUS_TOLERANCE_INCH = n Default 0.00005
CENTER_ARC_RADIUS_TOLERANCE_MM = n Default 0.00127
try playing with these setting, I have them set on my machine. Its been a while since Ive had that error but this is one of the things I did, I hope it actually does something. The other thing I did was tighten the arc tolerance when doing helical arcs, that was where I mostly had the issue.
28 Jan 2022 04:18 #233339 by smc.collins
Where are those settings located ?
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
28 Jan 2022 07:20 - 28 Jan 2022 07:23 #233350 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic LinuxCNC Paid Help
In your ini file under the relevant section heading. It may help to read the whole page that was linked.
/your_home_directorylinuxcnc/configs/name_of_your_config/
Last edit: 28 Jan 2022 07:23 by ALittleOffTheRails.
29 Jan 2022 20:43 #233482 by smc.collins
4 posts up I put up my configs,
30 Jan 2022 01:36 #233508 by smc.collins
changing the precision value in the prost processor for fusion 360 seems to have resolved the radius arc errors.
Time to email Autodesk
  • Visitor
  • Visitor
30 Jan 2022 01:44 #233509 by ALittleOffTheRails
You asked where those settings where located.
I just replied where they were located.
Instead of just (insert bad words here) whinging & complaining, how about a "thanks mate". Seriously if this is the way you treat people volunteering help I'd really hate to see how you would treat someone you paid for for help.
30 Jan 2022 19:49 #233571 by cakeslob
Sometimes the setting need to be added to the section
the link I provided was for the ini file under the rs274 section, so just add them in. it probably has less to do with autodesk and more to do with linuxcnc having a tight default tolerance
I will assume this means the arc tolerance is set to .00005" for imperial, most of the time i have my default arc tolerance for roughing set to .001" in mastercam. So see if gradually increasing that number makes a difference
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
CENTER_ARC_RADIUS_TOLERANCE_INCH = 0.0005
CENTER_ARC_RADIUS_TOLERANCE_MM = 0.00127
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
31 Jan 2022 06:39 - 31 Jan 2022 06:40 #233609 by smc.collins
Yeah i was searching inside the  ini files, and I was wondering if this was a case of needing to add a few lines to it.
Thank you, changing the post processor seems to maybe be a better fix however. I will be retrofitting 3 more hurcos for production work in the home shop shortly.
The tool changer looks to be daunting potentially.
Last edit: 31 Jan 2022 06:40 by smc.collins.
Time to create page: 0.223 seconds
