Computer spec question
  • muzza
  • muzza's Avatar Topic Author
  • Senior Member
  • Senior Member
14 Feb 2022 22:55 #234871 by muzza
Computer spec question was created by muzza
Total noob here.
I started building a Makerstore CNC machine about 4 years ago and just this week pulled it out and continued building it.
The chosen controller was a Gecko G540 hooked up to an old Dell Optiex980.
I tried to turn on the computer last night and it’s dead.
im a bit worried about buying another as they’re so old now.
What other options are they to connect the Gecko’s parallel port to a newer computer without a parallel port?
15 Feb 2022 03:04 #234881 by rodw
Replied by rodw on topic Computer spec question
You could try the mesa 7i92 ethernet card. Your BOB should plug into it.
or a 7i76e and redo it all.
15 Feb 2022 06:47 #234892 by arvidb
Replied by arvidb on topic Computer spec question
rodw's advice is probably the best option: it is future proof and will get you far better performace than a regular parallel port. It is a bit higher cost and will require some configuration changes (quite substantial with the 7i76e).
That said, it is still possible to get motherboards with an internal parallel port header, or you can buy a PCIe parallel port card for your new computer. The biggest issue with these options is that the host computer needs to have very low latency to be able to run the "base thread" that flips the parallel port pins, and it's difficult to know beforehand if a certain computer is good enough (this is not related to raw performance but has to do with how power saving, "management engines" and such are implemented on the board).
Pros: cheap; simple.
Cons: the computer you buy might not work; much lower step rates and much more jitter than a Mesa based system; you will need to run the no-longer-fully-supported RTAI version of LinuxCNC. Also with a PCIe parallel card you will need to set it up which seems to be not always straight-forward.
If you want to go this route, look around and see if you can find a computer with a parallel port header that others have been successful with. I would only go this route if money and/or time is very tight.
  • muzza
  • Senior Member
  • Senior Member
15 Feb 2022 09:26 - 15 Feb 2022 09:35 #234900 by muzza
Replied by muzza on topic Computer spec question
Hmmm. I think you misunderstood my first 3 words... Whenever I read the words 'require some configuration', my blood freezes and I feel ill.
I don't have any BOBs, (breakout boards, right?)  I've only got the Gecko G540. I believe the motor drivers are built in, therefore not requiring breakout boards???
I started this project 4-5 years ago and much of my research from that time is now a non-existent memory.
Whatever computer I get will have to be cheap, because its going to be permanently connected to the machine in the shed.
[EDIT:] I just bought an old Dell Optiplex 760 from feeBay last night for under $90AUD delivered, hopefully it will do the job... (and last longer than a few years...)
Last edit: 15 Feb 2022 09:35 by muzza. Reason: 1. I found the answer to one of my questions. 2. added note that I've purchased a 'poota'.
15 Feb 2022 09:58 #234904 by arvidb
I can guarantee one thing: once you have your machine up-and-running, you will no longer be a total noob. :D
15 Feb 2022 10:20 #234906 by tommylight
Replied by tommylight on topic Computer spec question
Dell 760 should do just fine, granted use the Wheezy ISO from the downloads page.
G540 has a very bad "idea" implemented (not sure what Marius was thinking), namely the /10 step divider, so every step the drive waits another 9 steps doing nothing. Well that was with version 1.2 or 2.1 or ... forgot what version i had, had 3 of them.
  • muzza
  • Senior Member
  • Senior Member
15 Feb 2022 13:33 #234919 by muzza
How do I tell which version I've got?
15 Feb 2022 14:33 #234933 by tommylight
uname -a
in a terminal.
15 Feb 2022 14:40 #234938 by arvidb
I don't think you can see what version of Geckos you have using uname? ;)
('uname -a' shows which kernel version you're running.)
15 Feb 2022 16:55 #234954 by tommylight
Ooops, i was thiking the question was for the version of Debian/wheezy.
G540 has the version printed on the board, but that requires opening it. It is not important at all, just check if it has a small switch for enabling/disabling charge pump.
Time to create page: 1.301 seconds
