Computer spec question
  • muzza
  • muzza's Avatar Topic Author
  • Senior Member
  • Senior Member
16 Feb 2022 00:14 #234995 by muzza
Replied by muzza on topic Computer spec question
Yes, it has a switch for the charge pump. I hope that’s a good thing?
  • Moderator
  • Moderator
16 Feb 2022 07:29 #235015 by tommylight
Replied by tommylight on topic Computer spec question
Yes it is as you can disable the charge pump, set up the configuration and make sure everything is working properly, then enable it again and set the charge pump in LinuxCNC.
Time to create page: 0.440 seconds
