Hi, considering there has not been any activity in this thread since March I hope it is ok if I borrows it. I bought an Emco 5 PC but the computer with LinuxCNC was broken so I downloaded Debian 10 and LinuxCNC 2.8.2 to a new one. I also downloaded the Half-fullstepMorph files found in this thread:
forum.linuxcnc.org/30-cnc-machines/26757...cnc-painless?start=0
Despite that this was my first ever experience of Linux it did well and I have no problem starting LinucCNC with Half-FullstepMorph-profile active. My problem is that I can not control the lathe from LinuxCNC. When I starts LinuxCNC and powering the lathe I can not push "Toggle Machine Power" in the interface because it is grayed out, to solve this I just put the computer to sleep and then wake it up again. When I do so I can hear a "click" from the lathe and the "Toggle Machine Power" is not grayed anymore.
The problem now is that it does not matter which button on the computer I press, the lathe does not do anything at all. The DRO-coordinates at the interface changes when I press the arrows but the lathe refuses to do anything. Is there a way to see if there is any connection between LinuxCNC and the lathe?
Debian 10
LinuxCNC 2.8.2
A6BA9B1012 (Lathe serial number.)
PCI - parallel:
www.amazon.se/dp/B000W2P15A/ref=pe_24982...03747021_TE_SCE_dp_1
I would be very glad if anyone has any suggestions to solve the issues.
Thanks,
Paul
