Emco compact 5 Pc pin out help
4 years 3 months ago #247580 by Franzmeizter
Ok, the good news is that LinuxCNC behaves like it should but unfortunately it still can not control the lathe :(
Is there a way to check the connection between LinuxCNC and the lathe? A green light that indicates communication would be nice.
andypugh wrote something about "enable config problem", is that the next step in this investigation? If it is, I have to admit that I do not know how to check it.
By the way, thank you for your patience tommylight.
4 years 3 months ago - 4 years 3 months ago #247585 by skunkworks
They probably removed the latching chip to make it work with mach3.. This thread might help you get a better overview of the pins and what they do.. (there are also configs - but remember it is based on a non-molested compact 5 pc..
www.cnczone.com/forums/emco-lathe/186598...hinist-software.html
sam
Last edit: 4 years 3 months ago by skunkworks.
4 years 3 months ago #247587 by skunkworks
lol - I saw you found my thread on here.. (I looked but didn't find it - so I linked the cnczone version)
Ok - make sure you have the safety 'plug' wired in correctly..
#Top for actual machine - bottom for testing.
net estop-ext <= parport.0.pin-11-in-not
#net estop-ext <= parport.0.pin-11-in
this has to be correct 'and' the plug for the saftey circuit has to be right.
plug x6 on the back of the lathe is what hooks to the 'chip guard' not all machines have that - so if not.
one of ours sockets has short wires jumpered in...
Looks like jumper pins 7 to 5 and 1 to 3 (from the schematic)
www.electronicsam.com/images/emco/GEDC0145.JPG .
4 years 3 months ago - 4 years 3 months ago #247596 by Franzmeizter
Hi Sam, was this message meant for me or for Kosta79? Because I do not think that mine ever was controlled under Mach3. I mean the one about the latching chip.
//Paul
Last edit: 4 years 3 months ago by Franzmeizter.
4 years 3 months ago #247597 by skunkworks
Yes Paul - you. Didn't notice this was 2 different people.
Those configs should work for your unmolested pc 5. Check the safety plug.
4 years 3 months ago #247598 by Franzmeizter
Thanks for answering! I know that there is an outlet (X6) for the chip guard at the back of the lathe, there is even a plug in the outlet but no cable. It could be that 7 and 5 + 1 and 3 are connected to each other inside the plug, I will check that tomorrow!
Time to create page: 0.087 seconds
