Emco compact 5 Pc pin out help
4 years 3 months ago #247678 by skunkworks
with the lathe powered up of course..
4 years 3 months ago - 4 years 3 months ago #247692 by Franzmeizter
No it does not, I tried to spin the spindle by hand and after that by turning the spindle power on but the rpm in LinuxCNC does not indicate anything at all.
In the lower left corner of the LinuxCNC window there is an on/off-indication but it does not change when I power of the lathe (actually, I do not know if it should change but it does not).I have attached a picture that is taken with the spindle motor running.
Last edit: 4 years 3 months ago by Franzmeizter.
4 years 3 months ago #247696 by skunkworks
What cable are you using to connect the computer to the lathe?
4 years 3 months ago #247713 by tommylight
In a terminal
cat /proc/ioports | grep parport
post the result
The following user(s) said Thank You: Franzmeizter
4 years 3 months ago - 4 years 3 months ago #247715 by skunkworks
I was thinking that if the parallel port wasn't getting detected by linuxcnc - you would be getting this error..  (unless the config was changed)
Last edit: 4 years 3 months ago by skunkworks.
4 years 3 months ago #247716 by skunkworks
Unless!!
There is an onboard printer port (header on the motherboard) that linuxcnc is using - and not the pci card!?
Time to create page: 0.132 seconds
