Heidenhain Encoder - strange waveform help request
4 years 7 months ago #236799 by Ivan_The_Red
I hooked up my spindle encoder which is a 420 series Heidenhain to my oscilloscope and even though the encoder is listed as a square wave TTL encoder , I saw a sine wave? Upon rotating the encoder shaft the scope showed what looked like a TTL square wave going on inside of a sine wave. I really dont know what to think of it but would like to know if thats normal. If its normal, is there anything special i need to do with my HAL file to deal with the strange waveform or do I just treat it like its a regular square wave signal. Im using a MESA 7I76 and 5125 for the interface.
4 years 7 months ago #236812 by scotth
Try here.
www.heidenhain.us › wp-content › uploads › 349529-2H_Rotary_Encoders_en.pdf
4 years 7 months ago #236910 by Ivan_The_Red
Well oscilloscopes tend to work better when you remember to hook up the probe grounds.....hahahaha...problem solved
4 years 7 months ago #236915 by scotth
Good. All I could find was 5Volt supply TTL square wave in a 420 encoder.
3 years 9 months ago - 3 years 9 months ago #261031 by fons
i have a liniair scale LS904 ml 370 from heidenhain on me mile machine
i'm not sure  if the scale is broken or  the input  of the controle unit fails
how can i find out if the scale work wel  ?
what is de basic set up ?
just power  5vdc  on  pin 3and  4 ?
when i use a scope between ground and  an output  what signal do i have to find  or do i need a pull up or down  resistor  ?
i found  in an old document  somthing like  15microampere on the output
do someone know how to test the scale
Last edit: 3 years 9 months ago by fons.
3 years 9 months ago - 3 years 9 months ago #261033 by PCW
These encoders typically need an interpolator interface card
(EXE series)
Last edit: 3 years 9 months ago by PCW.
Time to create page: 0.203 seconds
