Heidenhain Encoder - strange waveform help request
08 Jan 2023 00:13 #261218 by fons
it is a  Deckel FP2NC mill
when i power up  the machine  i see  the led inside the scale  is working
but on the display  of the control unit of the mill the  x-value don't apeare
y and z work
i change x and  y  and now i have 2 problems  only z is still actieve
maybe someone here had an old deckel console with the boards inside  ?
i need the  NZP board thats the input of the scale  maybe someone can help me out
08 Jan 2023 01:25 #261236 by sivaraj
fons post=261218 userid=27700it is a  Deckel FP2NC mill
y and z work
You tried swapping the whole scale or just on the port connectors of X & Y .
Either case of swapping it cannot destroy the Controller PCB as the 11uA scanner head just has a source LED and 4 photo diode for 11uA of A&B signals .
or 6 photo diodes including Z.No other electronics inside .
Linear scales with visible light source usually has separate proximity circuit for Z marker.Usally with a settable metal strip.
If source LED is visible working remaining is header gap alignment and wiring.
Scales of newer version will have infrared LED and invisible to naked eyes .
08 Jan 2023 11:44 #261255 by fons
can it be that i destroy the Controller PCB when i change the scale  with  power on  ? thats in fact what happend
i think its a very old scale  the mill was build in  1984 as fare i can see ther is only one scale replaced not thise one
08 Jan 2023 17:56 #261287 by andypugh
You can often see IR LEDS with a digital camera, though.
08 Jan 2023 19:45 - 08 Jan 2023 19:53 #261299 by fons
i do the check with an exe 601 box
the scale work partly  so it will be a dirt ploblem  how do i have to clean  this  ? i see a lot of movie  on youtube
Last edit: 08 Jan 2023 19:53 by fons.
