ATC Project - Debug phase
- spumco
- Thank you received: 905
17 May 2022 16:35 #243177
by spumco
Replied by spumco on topic ATC Project - Debug phase
Thanks Andy, I'll try the new comp file tonight.
Regarding the homed & state pins... they weren't in halshow. That was the first (maybe second) thing I thought to check while debugging, but that pin didn't exist under carousel in halshow.
carousel.0.state
carousel.0.homed
carousel.0.homing
are all missing from available pins in halshow -> carousel
carousel.0.timer was present.
carousel.0.state
carousel.0.homed
carousel.0.homing
- spumco
17 May 2022 22:07 #243208
by spumco
sudo: halcompile: command not found
Linux is making me feel dumb again.
- Thank you received: 7491
17 May 2022 22:26 #243211
Replied by tommylight on topic ATC Project - Debug phase
Do you have the dev installed?
sudo apt-get install linuxcnc-uspace-devPlease Log in or Create an account to join the conversation.
- spumco
17 May 2022 23:00 #243217
by spumco
unable to locate package linuxcnc-uspace-dev
Still feeling dumb.
Still feeling dumb.
18 May 2022 00:06 #243228
Replied by andypugh on topic ATC Project - Debug phase
Those are parameters, so you need to look in the parameters tab.Regarding the homed & state pins... they weren't in halshow. That was the first (maybe second) thing I thought to check while debugging, but that pin didn't exist under carousel in halshow.
18 May 2022 00:09 #243229
Maybe
sudo apt-get update
then
sudo apt-cache search linuxcnc
So am I, now.unable to locate package linuxcnc-uspace-dev
Still feeling dumb.
Maybe
sudo apt-get update
then
- spumco
18 May 2022 01:18 #243233
by spumco
Reading package lists...Done
sudo apt-cache seach linuxcnc
linuxcnc-uspace - motion controller for CNC machines and robots
sudo apt-get update
Still feeling dumb.
So am I, now.
Maybe
sudo apt-get update
then
18 May 2022 01:37 #243236
- spumco
18 May 2022 02:10 #243240
by spumco
I just wiped the PC (again.)
I think I had both a RIP and an installed version of LCNC; was running in to issues trying to load qtvcp sims, qtpyvcp wouldnt' show up anywhere (other than Probe Basic), and other phantom or inexplicable issues.
That, plus MX21 was giving me some problems with graphics/fonts not displaying properly regardless of the theme.
I want a clean, standard installation so I'm in the process of installing Debian 11 and will follow the LCNC instructions on the qtpyvcp page.
Once I'm back in business I'll revist the carousel issue and see where things are.
- spumco
20 May 2022 01:15 #243377
by spumco
Ok, I'm back on this with a fresh install of Bullseye & 2.9.
sudo apt-get isntall linuxcnc-uspace-dev
results in
E: Unable to locate package linuxcnc-uspace-dev
results in
Time to create page: 0.570 seconds
