ATC Project - Debug phase
4 years 4 months ago #245745
Replied by andypugh on topic ATC Project - (not again...)
There won't be a cumulative error, no. It is just a "window" that means that it doesn't have to see an exact count to register a new position.
Try 4 first, see if that fixes 50 speed units.
I am not sure what your step rate is at 50 units, but if you imagine that it only checks the step count every 1mS, if you have more than 1000 steps / second it is going to start missing a pocket sometimes if there is no leeway allowed.
- spumco
- Thank you received: 905
4 years 4 months ago - 4 years 4 months ago #245754
by spumco
Replied by spumco on topic ATC Project - (WOO!!!)
OMG - progress.
I set width to 5 and it's stable up to speed = 150. Also had to set the stepgen maxaccel = 0 & maxvel = 0; with those at 'soft' settings it would coast past a pocket (or 3) regardless of whether carousel was getting the counts right.
Since I cant really figure out what the speed units are, I used the stepper tuning software to monitor the RPM via rs232.
150 units = ~100 motor RPM, 20 carousel RPM (5:1 gearbox). So with a 4500ppr step count that's a pulse rate of about 7.5khz.
It was actually stable up to 200 units, which was proper fast. Like Robodrill tool changes.
Thanks a ton Andy.
Now that hurdle is behind me, I'm happy to do more testing if you want to fiddle with the homing or pin sense functions.
PS - while I'm asking for favors, an additional nice-to-have would be the ability to unhome the carousel without having to shut down LCNC and restart it.
Thanks a ton Andy.
Last edit: 4 years 4 months ago by spumco. Reason: Update silly title
4 years 4 months ago #245764
If your step scale is set to give degrees of carousel motion then it would be degrees per second. If it was set to one motor revolution then it would be motor revs per second.
Probably
Replied by andypugh on topic ATC Project - (WOO!!!)
The speed units are things-per-second, but that rather depends on how you have scaled the step generator.Since I cant really figure out what the speed units are, I used the stepper tuning software to monitor the RPM via rs232.
Probably
- spumco
4 years 4 months ago #245779
by spumco
That would meat it's it degrees/second since I've got the stepgen scale set to 50. Or at least it was until I changed the microstepping in the drive to see if different values would change the rotational issue sorted out yesterday. This passes the sanity test since 150 degrees per second looks about like 20rpm to the untrained eye.
Next moves:
Next moves:
- Remove unused pocket pins & make a better index flag
- Remap M6
- Test sequencing and actually change a tool
- Connect various other remaps to Probe Basic GUI buttons
- Profit
4 years 4 months ago #245783
Hold off on that. I think that adding a latching move can make the work well. In principle I like the pins.
- spumco
4 years 4 months ago #245786
by spumco
Easy enough to reconnect sense-01 back in hal; nothing was actually removed from the machine.
Holding, Aye.
Time to create page: 0.134 seconds
