ATC Project - Debug phase
4 years 4 months ago - 4 years 4 months ago #245371 by spumco
Replied by spumco on topic ATC Project - (Update)
Sorry, don't understand the question.  Where is it physically?  Or the hal connections?
EDIT - or the carousel.comp file?  It's located in linuxcnc-dev/src/hal/components/
And I double-checked by opening carousel.comp in that location and it's the modified version (i.e. line 396 changed to "old_index = ind;"
And carousel.c has a Date Modified = Today, so I'm fairly sure the new version is installed/compiled.
Last edit: 4 years 4 months ago by spumco.
4 years 4 months ago #245527 by andypugh
Replied by andypugh on topic ATC Project - (Update)
Where is it physically. Is it practicable for me to beat it into submission in person?
4 years 4 months ago #245533 by spumco
Depends on your location.  I'm in Ohio, USA, so it does not require space travel.
Or I can ship the pieces to you for a personal Advent Calendar of Industrial Aggression episode.  Your choice.
Seriously - have you just lost interest?  I can go back to beating my head against the ATC-as-axis option.
If you want a physical duplicate to test with, I'll be happy to buy a stepper, drive and cheapo gearbox and have them sent to you.  'Cause thats all it really is.
4 years 4 months ago #245538 by tommylight
Replied by tommylight on topic ATC Project - (Update)
I foresee a "open source DIY CNC tool changer" in the making.
Now if that was 3D printed, i would have it working by tomorrow! :)
Thinking of it i never searched for something like that....
No go, turns back results for 3D printer tool changers! :(
4 years 4 months ago #245548 by spumco
I think I read an older post on this board to the effect of: "Building an ATC is easy.  Programming is the hard part."
They weren't kidding.  I guess the only hard part of the actual build was finding a good quality planetary reducer for cheap.  Everything else has been relatively uncomplicated.
If we can come up with a reliable control scheme that works reliably and doesn't require a geneva drive or encoder, that'd lower the bar for quite a few people.
And when I say "we", I mean "Andy & others" while I do what they tell me.
4 years 4 months ago #245557 by tommylight
-Use "carousel" component as is
-Use a stepper motor or step/dir servo
-use an index and a pocket sensor
-3D printed almost everything???
-Use stepper for arm motion???
Just some random thoughts ...
Anyone good with 3D design?
Time to create page: 0.206 seconds
