- Thank you received: 905
ATC Project - Debug phase
- spumco
4 years 3 months ago #246657
by spumco
Replied by spumco on topic ATC Project - (Remap Phase)
You know, I just went through the Probe Basic example stdglue and there are a LOT of differences from the latest in LCNC - not just the one I posted above. And I see a number of changes in github to the file in the past couple of years - meaningful changes, not just documentation updates.
I think I'm going to try using the standard one this evening and see what happens.
Can I delete all the #REMAP=S, #REMAP=T, and # pure python remaps stuff I don't need?
4 years 3 months ago #246661
Replied by andypugh on topic ATC Project - (Remap Phase)
You can definitely remove any commented-out entries and you will see no difference in behaviour.
But sometimes they can be useful references for things that you have already tried.
- spumco
4 years 3 months ago #246669
by spumco
Sorry Andy, I was unclear with my question.
Specifically, the newer LCNC version of stdglue has numerous sections (for lack of a better term) which I believe are intended to be templates for remapping T, S, F, M6, M61 words/codes. In addition, there's a section on the end which appears to be a template for a pure python remap.
I was curious which of these template sections, if any, I could simply get rid of (or comment out). I'm not trying to remap anything but M6.
- spumco
4 years 3 months ago #246687
by spumco
Replied by spumco on topic ATC Project - (Remap Progress)
Finaly, some tangible progess today.
Tried using the 'standard' stdglue.py from LCNC, and no significant change in behavior. While fiddlign with it, I discovered that remap is not passing #<_selected_pocket> through to local variable #<selected_pocket>. It is passing the other global parameters through.
That's what's been throwing me off for days, as I was changing the first one (selected_tool) or all three - but not just the last one.
So this:
#100 = #<selected_tool>
#110 = #<tool_in_spindle>
#120 = #<selected_pocket>
Had to be changed to:
#120 = #<_selected_pocket>
Changed it in both my main toolchange.ngc and the m22.ngc (unloads tool from spindle), and some stuff started happening... like the PDB started activating, spindle oriented. WOO!
Challenge the next is trying to pass through INI values to the remap o-codes. I have Z-high, medium, and low positions and fast & slow speeds I'd like to have the head move to/at during the process. And I'd really like to have those values in one place, not repeated across 3-4 files (with a high probability of crashy-error).
INI file has this section:
and my two sub-routines have references to those values like so:
I've tried removing the outer "[...]" from the references.
I've tried changing to lower case.
I've tried connecting them to local named variables:
But no dice. I've even added the [RS274NGC] INI_VARS = 1 statement (supposed to be default), but the INI values aren't passing through.
Every permutation of (DEBUG, the value of parameter z_med is #<_ini[ATC]ZMED]>) results in ##### (for all the INI values, not just ZMED).
So close, but still stumped.
So this:
[ATC]
POCKETS = 18
ZHIGH = 0
ZMED = -0.9 #change to -3.000 after testing
ZLOW = -1 #change to -3.200 after testing
ZFAST = 20 #speed up after testing
ZSLOW = 10 #speed up after testing
G1 G53 Z[#<_ini[ATC]ZMED] F[#<_ini[ATC]ZFAST] ; Move to head to above tool change position FAST
G1 G53 Z[#<_ini[ATC]ZLOW] F[#<_ini[ATC]ZSLOW] ; Move to head to tool change position SLOW
#z_med = #<_ini[ATC]ZMED
- spumco
4 years 3 months ago #246688
by spumco
PS - don't want to hose up the editing above.
I tried changing #<selected_pocket> to #<pocket>, and that didn't work. The only positive result was switching to the global parameter.
- spumco
4 years 3 months ago #246689
by spumco
Comments.
COMMENTS COMMENTS COMMENTS!!!
Take the comments after the values out and it works:
to this:
And it's working. There are other INI sections/values with comments and those work... but I don't care why right now.
OMG LinuxCNC is so hyper-specific I'm going to cry.
"I'm sorry, Hal, I can't do that."
This is like the worst Easter-egg hunt in the universe. On to the next battle...
Comments.
to this:
ZMED = -0.9
ZLOW = -1
ZFAST = 20
ZSLOW = 10
The following user(s) said Thank You: tommylight, pommen
Time to create page: 0.175 seconds
