- Thank you received: 905
ATC Project - Debug phase
- spumco
4 years 3 months ago #246770
by spumco
Replied by spumco on topic ATC Project - (More Remap Progress)
It's moving!
Huge step forward last night... all the remaps are being called at the right time and sort-of doing what they're supposed to.
TLDR: I've got (at least) two problems now: one big, one small.
Smaller one is that one of the sequencing moves (Z-up after grabbing tool) isn't happening. The 'Z-up' line is in the ngc file, and I can see the (print,...) statements before and after it, but it's not executing every time it's supposed to. Result is that the head stays down when the tool change is complete - not good as this will lead to a crash in certain circumstances.
Bigger issue is that I just figured out (mostly) how Probe Basic is handling tools and pockets. I finally got the atc_sim working (there's a minor python to python3 bug in a gui file) and watched how everything is choreographed.
Probe Basic doesn't use LCNC tool table pockets; it keeps track of which tool is in which pocket with extra parameters in the main parameters .var file. The tool table in the sim even has the 'standard' pocket column hidden - now I know why.
I guess the intent was that the user just looks at the on-screen ATC widget and there's your tool in some pocket. You aren't supposed to care about the pocket number: PB keeps track of what's where and won't let you load the same tool twice, or try to over-load the carousel.
But my carousel.comp-controlled ATC is using the LCNC tool table pocket numbers to move and keep track of where things are.
Further complicating things, I appear to have based my config on the non-ATC Probe Basic sim config, not the sim-ATC config. Most of the back-stage qtpyvcp and python files are missing from my setup.
I can see the on-screen tool widgets getting put in the ATC widget pockets, but I now understand why tools are getting lost on-screen from time to time. And, more importantly, why the carousel doesn't stay put when it's supposed to - or it moves to a different pocket than intended.
Example:
Not good. Of course, I don't have any tools installed and I've limited the head to Z-1.000 so there's no actual crashing right now. But it would have.
Initial conclusion is that I'm going to have to figure out how to control carousel.comp using the Probe Basic scheme. I suspect this is where I'm going to have to start:
The above is, I think, the reason PB and carousel aren't really talking to each other properly. It may be as simple as changing the ngc file(s) from
to
But I'm not quite sure yet. Still have to internalize how PB is reading/writing the parameter values and when.
All suggestions welcome, of course.
The alternative is to abandon carousel.comp and revisit treating the ATC like an axis. Don't really want to do that, however; starting from square one on stuff I don't understand doesn't appeal.
PS - This is moving in to a QtpyVCP/PB phase of the 'dear diary' thread and less a "General LinuxCNC Questions" thread. Maybe best to move it? I'll leave that to the moderators.
Example:
- T10 in spindle
- T8 in pocket #8
- Pocket #10 empty and lined up with spindle
- T8 M6
- ATC rotates to pocket #8, puts T10 in pocket #8 (with T8 in the pocket) and loads T8 in spindle.
net ATC_POS_REQ <= motion.analog-out-00 #pocket position request
net ATC_POS_REQ => conv-float-s32.0.in #pocket position request convert to s32
net ATC_POS_S32 <= conv-float-s32.0.out
net ATC_POS_S32 => carousel.0.pocket-number #pocket position request to carousel.comp
M68 E0 Q#<_selected_pocket> ; Set selected-pocket
M68 E0 Q#<[b]mystery_parameter[/b]> ; Set selected-pocket
- spumco
4 years 3 months ago #246818
by spumco
On further review, I may have been hasty in my earlier speculation about how Probe Basic manages the toolchange process.
Reviewing the atc-sim config (I didn't have before), I found that the sim is loading carousel.comp in index mode - along with the usual carousel.0.pocket-number connection to motion.analog-out-nn.
I'm not going to try editing my last post and mess up the formatting, but I'm sure I haven't really figured out how everything is related. Still not sure where the pocket numbers are coming from, and I still think PB is ignoring the tool table pocket values, but the conversion may be less painful than I was worried about in the last post.
4 years 3 months ago #247161
You need to close the <> pairs in the parameter names.
Replied by andypugh on topic ATC Project - (Remap Progress)
Finaly, some tangible progess today.
Code:G1 G53 Z[#<_ini[ATC]ZMED] F[#<_ini[ATC]ZFAST]
G1 G53 Z[#<_ini[ATC]ZMED>] F[#<_ini[ATC]ZFAST>]
- spumco
4 years 3 months ago #247198
by spumco
Replied by spumco on topic ATC Project - (Remap Progress)
Thanks Andy.
I've gone dark for the past couple of days, but have been working on this continuously. I seem to have accidentally 'fixed' the error you pointed out like so:
instead of using the INI values directly in the gcode.
I also found that I was duplicating a numbered parameter in the toolchange.ngc file. I think that was causing one of the ATC widgets to disappear and throwing off some calcs. When I added more pockets than the sim (18 vs 12) the additional parameters which represent the pocket numbers duplicated another one used for something else later on in the file.
Just yesterday I had another 'Ah-Ha' moment and realized two things:
And since my carousel isn't being commanded like the sim is, the built-in widget isn't moving like I expected it to. However, tonight's experiment will be to see if the Probe Basic devs left an easter egg for people like me. Found this in the atc_motion.hal file:
And some similar stuff which might allow me to manage the on-screen ATC widget without the (DEBUC, EVAL...) stuff. My initial thought is that I'll basically be commanding two ATC's at once - the real one and the on-screen version.
I'll report back with tears of shame or elation.
#<z_high> = #<_ini[ATC]ZHIGH>
#<z_med> = #<_ini[ATC]ZMED>
#<z_low> = #<_ini[ATC]ZLOW>
#<z_fast> = #<_ini[ATC]ZFAST>
#<z_slow> = #<_ini[ATC]ZSLOW>
G1 G53 Z#<z_med> F#<z_fast>
- That the bulk of the HAL files in the Probe Basic atc_sim config are used to drive a vismach display, not the ATC widget or LCNC motion. That seems to be where the carousel.comp component is being used and why nothing was connected to it in halshow
- That the ATC widget is being homed & moved using those cryptic (to me) lines like
DEBUG, EVAL[vcp.getWidget{"dynatc"}.rotate{#<Steps_to_move>, "ccw"}])
# this allows to move the carousel widget from gcode using motion pins
net atc-goto-in-float atc-widget.goto <= motion.analog-out-09
net atc-goto-enable-in-bit atc-widget.goto-enable <= motion.digital-out-12
- spumco
4 years 3 months ago #247204
by spumco
Tears of shame.
It looks like that atc_motion.hal file isn't attached to anything, or called up /referenced by anything. There's no extra .comp file to create the widget pins, and none of the python files in the config or main PB folders appear (to my python-ignorant self) to reference anything like "atc_widget.something"
Frankly, it looks like another of the PB devs' tangents that hasn't been fully flushed out yet. Or I don't understand it.
Back to the (DEBUG...) stuff.
4 years 3 months ago #247225
That is indeed somewhat cryptic. I don't actually know what EVAL does (and haven't found it in the code, yet)
I thought at first it was the (not-very-documented) ability to call Python directly but that uses (PY, ) as a magic comment.
[/code][/code]Code:[code]That the ATC widget is being homed & moved using those cryptic (to me) lines like [code]DEBUG, EVAL[vcp.getWidget{"dynatc"}.rotate{#<Steps_to_move>, "ccw"}])
Time to create page: 0.132 seconds
