OpenCV with Linuxcnc 2.8.0 ?
- Thank you received: 7464
23 Apr 2022 01:04 #240950
Replied by tommylight on topic OpenCV with Linuxcnc 2.8.0 ?
If your feeling lucky, have a go at this, i just posted it, and edited, and edited, and .... where was i
https://forum.linuxcnc.org/9-installing-linuxcnc/45683-linuxcnc-on-debian-unstable-for-testing-only
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Thank you received: 445
23 Apr 2022 01:06 - 23 Apr 2022 01:11 #240951
by my1987toyota
Replied by my1987toyota on topic OpenCV with Linuxcnc 2.8.0 ?
Last edit: 23 Apr 2022 01:11 by my1987toyota.
23 Apr 2022 01:22 #240952
It's 3:22AM here, so if i messed up, wait till tomorrow to tell me!
- my1987toyota
23 Apr 2022 01:53 #240954
by my1987toyota
- Thank you received: 4140
23 Apr 2022 04:08 #240966
Its even easier on Debian. Just install debian Bookworm aka testing
and open synaptic and search for linuxcnc and install linuxcnc-uspace and linuxcnc-uspace-dev
This will bring in the PREEMPT_RT kernel.
Replied by rodw on topic OpenCV with Linuxcnc 2.8.0 ?
oh well so long beaglebrains special.
- my1987toyota
23 Apr 2022 12:35 #240986
by my1987toyota
I must be out of practice running a new iso. with a current linux distro already on the main drive . I tried running Debian 11 (wouldn't load)
I tried Debian 11 non free. Same problem. I tried running my usual beaglebrains special (again same issue) . Before you ask yes I made sure
the boot order favored my usb dvd drive first it is the Dell 9020 micro after all. And also yes I tried different USb ports to see if that was the problem. I wonder if the new installs favor UEFI over BIOS now . But that shouldn't have prevented the Special from loading. I may have to search for how to blank the boot drive and see if that fixes it. I am kind of at a loss.
23 Apr 2022 13:14 #240990
Use Rufus to write the image to USB.
Or if you are on Mint, start>preferences>disks
there choose the USB on the left side, then click on the "3 vertical dots" on the upper right side and choose restore disk image.
- my1987toyota
23 Apr 2022 13:24 #240991
by my1987toyota
24 Apr 2022 04:13 #241049
Also on Debian 11, I just let it run UEFI or not! Maybe it does favour UEFI
- my1987toyota
24 Apr 2022 10:54 #241060
by my1987toyota
The install on one of my test computers is going as I type this.
Maybe. However for me it has proven to be my portable external DVD drive was the culprit. I received the replacement this morning.rodw post=241049 userid=20660Also on Debian 11, I just let it run UEFI or not! Maybe it does favour UEFI
Time to create page: 0.197 seconds
