accidentally unplugged pc. Now I get an error
- ALittleOffTheRails
- Visitor
25 Apr 2022 05:37 - 25 Apr 2022 05:39 #241157
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic accidentally unplugged pc. Now I get an error
Ok thanks for that, I see things clearly now.
What in the way of drivers did you attempt to install. And did you reboot after installing ?
And can you runas most recent kernels "should" support PCI parallel ports.
Haha you did it already
And can you run
sudo lspciHaha you did it already
Last edit: 25 Apr 2022 05:39 by ALittleOffTheRails.
- muzza
- Thank you received: 6
25 Apr 2022 06:07 #241164
by muzza
Replied by muzza on topic accidentally unplugged pc. Now I get an error
I couldn't FIND the drivers. So I couldn't install them.
The PCI card just started working out of the blue. Now it's not...
Contents of sudo lspci:
muz@LinuxCNC:~$ sudo lspci
[sudo] password for muz:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a4)
00:1f.0 ISA bridge: Intel Corporation C216 Series Chipset LPC Controller (rev 04)
00:1f.2 RAID bus controller: Intel Corporation 82801 SATA Controller [RAID mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:02.0 Parallel controller: Device 1710:9865
muz@LinuxCNC:~$
muz@LinuxCNC:~$
- Visitor
25 Apr 2022 06:41 - 25 Apr 2022 06:45 #241166
lscpi -vnn
Will supply a bit more info.
I've had a look around and I can't seem to find a driver that matches the device ID of the Parallel Port. Linux matches drivers on the ID of a device.
There is the option of forcing a driver to load for the parallel port, we can give that option a go if you want.
I have a couple PCI parallel port cards that should work. If you're some where Down Under I could throw one your way after a little more testing.
As to why it worked then didn't I have no idea.
Maybe the case was moved around a bit when you tripped on the cable.
You could shutdown, remove the card, reboot, shutdown again and re insert the card and see what happens.
Last edit: 25 Apr 2022 06:45 by ALittleOffTheRails.
- muzza
25 Apr 2022 07:30 #241171
by muzza
I've tried shutting down, removing, rebooting, shutting down, reinserting, rebooting.
Same error.
I'm in Queensland.
Same error.
I'm in Queensland.
- muzza
25 Apr 2022 07:33 #241172
by muzza
FWIW, the card has an MCS9865 chip>
muz@LinuxCNC:~$ lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller [8086:0150] (rev 09)
Subsystem: Dell Device [1028:053a]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller [8086:0162] (rev 09) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f7800000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:14.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller [8086:1e31] (rev 04) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7c20000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller [0780]: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 [8086:1e3a] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f7c3c000 (64-bit, non-prefetchable)
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection [8086:1502] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at f7c00000 (32-bit, non-prefetchable) [size=128K]
Memory at f7c39000 (32-bit, non-prefetchable) [size=4K]
I/O ports at f080
Kernel driver in use: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04) (prog-if 20 [EHCI])
Memory at f7c38000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at f7c30000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1d.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 [8086:1e26] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7c37000 (32-bit, muz@LinuxCNC:~$ lspci -vnn
I/O ports at f000
I/O ports at f080
Memory at f7c37000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev a4) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 00002000-00002fff
Memory behind bridge: dfb00000-dfbfffff
00:1f.0 ISA bridge [0601]: Intel Corporation C216 Series Chipset LPC Controller [8086:1e53] (rev 04)
00:1f.2 RAID bus controller [0104]: Intel Corporation 82801 SATA Controller [RAID mode] [8086:2822] (rev 04)
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
Memory at f7c36000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller [8086:1e22] (rev 04)
Flags: medium devsel, IRQ 18
Memory at f7c35000 (64-bit, non-prefetchable)
I/O ports at f040
01:02.0 Parallel controller [0701]: Device [1710:9865] (prog-if 03 [IEEE1284])
Subsystem: Smart Link Ltd. Device [2000:2000]
Flags: medium devsel, IRQ 255
I/O ports at 2000 [disabled]
I/O ports at 2008 [disabled]
Memory at dfb00000 (32-bit, muz@LinuxCNC:~$ lspci -vnn
I/O ports at f000
I/O ports at f080
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
I/O ports at f040
Memory at dfb00000 (32-bit, non-prefetchable) [disabled] [size=4K]
Memory at dfb01000 (32-bit, non-prefetchable) [disabled] [size=4K]
muz@LinuxCNC:~$
muz@LinuxCNC:~$
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
I/O ports at f040
muz@LinuxCNC:~$
I/O ports at f000
I/O ports at f080
I/O ports at f000
I/O ports at f080
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
I/O ports at f040
I/O ports at f000
I/O ports at f080
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
I/O ports at f040
muz@LinuxCNC:~$
muz@LinuxCNC:~$
I/O ports at f0d0
I/O ports at f0c0
I/O ports at f0b0
I/O ports at f0a0
I/O ports at f060
I/O ports at f040
muz@LinuxCNC:~$
- Visitor
25 Apr 2022 07:52 #241175
Ok I found a dual port card and a couple of single port cards, all have been stored in the "Useful Box".
Info on the dual card from lspci:
If you are interested I can send you either one for the price of postage....I'd go for the dual port one
If the PM thing works we can give that a go, if not I can quickly post up my email and we work it out.
06:0d.0 Parallel controller [0701]: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller [9710:9865] (prog-if 03 [IEEE1284])
Subsystem: Device [a000:2000]
Flags: bus master, fast Back2Back, medium devsel, latency 32, IRQ 22
I/O ports at 3008 [size=8]
I/O ports at 3000 [size=8]
Memory at f6301000 (32-bit, non-prefetchable) [size=4K]
Memory at f6300000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [48] Power Management version 2
Kernel driver in use: parport_pc
Kernel modules: parport_pc
06:0d.2 Parallel controller [0701]: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller [9710:9865] (prog-if 03 [IEEE1284])
Flags: bus master, fast Back2Back, medium devsel, latency 32, IRQ 20
I/O ports at 3018 [size=8]
I/O ports at 3010 [size=8]
Memory at f6303000 (32-bit, non-prefetchable) [size=4K]
Memory at f6302000 (32-bit, non-prefetchable) [size=4K]
Kernel modules: parport_pcdmesg | grep parp
[ 7.302821] parport0: PC-style at 0x3008, irq 22 [PCSPP,TRISTATE,EPP]
[ 7.407706] lp0: using parport0 (interrupt-driven).
[ 7.408016] parport1: PC-style at 0x3018, irq 20 [PCSPP,TRISTATE,EPP]
[ 7.495701] lp1: using parport1 (interrupt-driven).If you are interested I can send you either one for the price of postage....I'd go for the dual port one
- Visitor
25 Apr 2022 10:18 #241184
If you leave an inquiry here www.vmn.com.au/contact Rodw (he's from your part of the world )will pass contact details on we can go from here.
- Thank you received: 7461
25 Apr 2022 11:35 #241197
Replied by tommylight on topic accidentally unplugged pc. Now I get an error
In a terminal:What address did you enter in StepConf?
sudo dmesg | grep parpPlease Log in or Create an account to join the conversation.
- Visitor
25 Apr 2022 11:46 #241198
There is no driver compiled with that PCI ID, so dmesg will show no info regarding parallel port. And the addresses of the card show as "disabled".
Even searching online for a the PCI ID, brings up nothing useful.
As seen below using the vendor ID (1710) brings up no matches for anything matching a paralell port.
cat /lib/modules/5.4.0-90-generic/modules.alias | grep 1710
alias pci:v000013FEd00001731sv*sd*bc*sc*i* adv_pci1710
alias pci:v000013FEd00001713sv*sd*bc*sc*i* adv_pci1710
alias pci:v000013FEd00001711sv*sd*bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv00001000sd0000D102bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000C202bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000C102bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000B202bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000B102bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd00000002bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv00001000sd0000D100bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000C200bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000C100bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000B200bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd0000B100bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000013FEsd00000000bc*sc*i* adv_pci1710
alias pci:v000013FEd00001710sv000010B5sd00009050bc*sc*i* adv_pci1710
alias pci:v00001093d00001710sv*sd*bc*sc*i* ni_65xx
alias i2c:bh1710 bh1750
alias of:N*T*Crohm,bh1710C* bh1750
alias of:N*T*Crohm,bh1710 bh1750
alias pci:v000013F6d00008788sv000014C3sd00001710bc*sc*i* snd_oxygenPlease Log in or Create an account to join the conversation.
25 Apr 2022 11:55 #241199
Time to create page: 0.180 seconds
