accidentally unplugged pc. Now I get an error
- ALittleOffTheRails
- Visitor
25 Apr 2022 12:46 #241202
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic accidentally unplugged pc. Now I get an error
cat /lib/modules/4.19.195-rtai-amd64/modules.alias | grep 2000 | grep par
alias pci:v00009710d00009865sv0000A000sd00002000bc*sc*i* parport_pc
alias pci:v00009710d00009901sv0000A000sd00002000bc*sc*i* parport_pc
alias pci:v00009710d00009912sv0000A000sd00002000bc*sc*i* parport_serialPlease Log in or Create an account to join the conversation.
- Thank you received: 4652
27 Apr 2022 23:20 #241412
Replied by andypugh on topic accidentally unplugged pc. Now I get an error
Days too late, but LinuxCNC has its own special driver which works at the port level. You should not need any other driver for a compliant parallel card. And a non-compliant parallel card probably won't work at all.Background info; I've spent the morning trying to install the drivers for a PCI parallel card. I couldn't find the drivers anywhere, but suddenly the parallel port started working. NFI.
