recommended pendant that just works, with current versions 2.8.x on
4 years 6 months ago #241592 by smc.collins
looking for pendant for use with my mills, saw some back and forth on it, what is the current consensus, upto 4 or 5 axis would be very handy.
4 years 5 months ago #241869 by andypugh
I think that the WHB / XHC ones still work, but have never tried one.
Try to get one that matches a driver here:
linuxcnc.org/docs/stable/html/man/man1/xhc-hb04.1.html
linuxcnc.org/docs/stable/html/man/man1/xhc-whb04b-6.1.html
And you should be OK.
The following user(s) said Thank You: smc.collins
4 years 5 months ago #241882 by smc.collins
before |I googlefu this, is there a pcb that uses this protocol and driver that I could wire up to my existing panel controls ?This is more of a curiosity than anything
4 years 5 months ago #241883 by tommylight
If you mean a panel control board that is wired to the machine, see Mesa 7i73, especially if you already have Mesa boards in use as the wiring to the control board is simple, a single UTP cable.
4 years 5 months ago - 4 years 5 months ago #241885 by smc.collins
I was wondering if they had something, I see they do.
I am thinking about taking out the joystick and swapping a rotary wheel, or should I just add the rotary wheel ?
Last edit: 4 years 5 months ago by smc.collins.
4 years 5 months ago #241886 by andypugh
I don't miss having a joystick.
Time to create page: 0.329 seconds
