recommended pendant that just works, with current versions 2.8.x on
05 May 2022 05:14 #242020 by rodw
Connect it to halui.mode.is-teleop so it selects the correct mode for MPG jogging.
Just to save confusion, I think that you mean halui.mode-teleop?
Though, now I look, I use halui.mode-manual to enable wheel jogging from the apron controls with my lathe.
Andy you are right. I checked my config now I'm at work. The reason I did it initially was with Gmocappy the jogging is on a seperate tab and the pendent was not enabled until that tab was selected.  halui.mode-teleop selects that tab in Gmoacappy. so its happy here. Its so long ago, I can't remember if I even tried the manual mode selection.
05 May 2022 08:16 #242024 by elf
I wouldn't trade my VistaCNC P4-S for that XHC :) I like having the screen showing current position and velocity on it.
The following user(s) said Thank You: caretech
Time to create page: 0.267 seconds
