- LinuxCNC
- General LinuxCNC Questions
- recommended pendant that just works, with current versions 2.8.x on
- smc.collins
- Thank you received: 139
29 Apr 2022 00:14 #241592
by smc.collins
recommended pendant that just works, with current versions 2.8.x on was created by smc.collins
looking for pendant for use with my mills, saw some back and forth on it, what is the current consensus, upto 4 or 5 axis would be very handy.
- Thank you received: 4652
02 May 2022 19:49 #241869
Replied by andypugh on topic recommended pendant that just works, with current versions 2.8.x on
I think that the WHB / XHC ones still work, but have never tried one.
Try to get one that matches a driver here:
linuxcnc.org/docs/stable/html/man/man1/xhc-hb04.1.html
linuxcnc.org/docs/stable/html/man/man1/xhc-whb04b-6.1.html
And you should be OK.
The following user(s) said Thank You: smc.collins
- smc.collins
02 May 2022 21:35 #241882
by smc.collins
Replied by smc.collins on topic recommended pendant that just works, with current versions 2.8.x on
before |I googlefu this, is there a pcb that uses this protocol and driver that I could wire up to my existing panel controls ?This is more of a curiosity than anything
- Thank you received: 7468
02 May 2022 21:40 #241883
Replied by tommylight on topic recommended pendant that just works, with current versions 2.8.x on
If you mean a panel control board that is wired to the machine, see Mesa 7i73, especially if you already have Mesa boards in use as the wiring to the control board is simple, a single UTP cable.
- smc.collins
02 May 2022 21:42 - 02 May 2022 21:47 #241885
by smc.collins
I was wondering if they had something, I see they do.
I am thinking about taking out the joystick and swapping a rotary wheel, or should I just add the rotary wheel ?
Last edit: 02 May 2022 21:47 by smc.collins.
02 May 2022 21:43 #241886
I don't miss having a joystick.
- Thank you received: 4145
03 May 2022 07:04 #241899
Replied by rodw on topic recommended pendant that just works, with current versions 2.8.x on
If you really want something that just works and you have plenty of inputs, skip the USB pendants and get one of the XHC professional 433 Mhz pendants that have a receiver hardwired in. They are 6 axis. Shown here at top left wired into a Mesa 7i76e and using the Mesa MPG. You can see the antenna cable in this pic.
Sorry don't have pics of the remote handy.
- smc.collins
04 May 2022 01:50 #241964
by smc.collins
04 May 2022 02:21 #241966
Yes, exactly what I have. Several in fact. Sending one to Ireland today.
Initially you needed to specify 5V encoder but thats now programmable or selectable with a link.
Also, you can ask or set the axis and scale selection to be digital to reduce the number of pins. This need a bit more hal plumbing to use MUX components but it lets you select 6 axes with just 3 pins. (2 for the 3 position scale)
7i76e I/O becomes very full once fully wired in so saving a few pins is worth it!
You cannot use the MPG without holding the yellow button down. There is an output for this button. Connect it to halui.mode.is-teleop so it selects the correct mode for MPG jogging.
The Estop input is designed to be used in an external to linuxcnc estop chain controlled by a safety relay with reduneant estop circuits which is nice..
The 3 function buttons I have not really used as it can be a bit dangerous if you accidentally bump cycle start! I was going to AND2 them with the yellow button so it had to be held down to activate the functions next time.
If you are in or near Australia, let me know I might be able to get a better price away from AliExpress. I was thinking of ordering another.
04 May 2022 20:45 #242001
Though, now I look, I use halui.mode-manual to enable wheel jogging from the apron controls with my lathe.
Just to save confusion, I think that you mean halui.mode-teleop?Connect it to halui.mode.is-teleop so it selects the correct mode for MPG jogging.
- LinuxCNC
Time to create page: 0.289 seconds
