Reference lathe
- Ingo
I'm banging my head. I have a back lathe, I want X=0 (G53) to be at the center of the spindle. My positive X is on top (top) and my reference is too.
There are two situations or it refers up there and it becomes zero then I don't have my X=0 in the center of the plate or I inform "HOME_OFFSET= 100" for example then it references up there and it goes down 100 (considering that the 100 would be the distance from the reference to the center of the plate), but I don't want that. I would like it to reference up there normal, but stay up there with the value of 100 positive, then when calling G53 or X=0 it comes to the center of the board. Does anyone have any suggestions?
Ingo
- Thank you received: 2181
Also when you say you want X=0 be the center of the spindle, what will be in the center of the spindle? A reference tool tip?
- JPL
- Thank you received: 118
See: linuxcnc.org/docs/html/config/ini-config...ha:ini-configuration
- Ingo
- Ingo
- Ingo
HOME_OFFSET and HOME are two completely different things.
It would be better to call them ORIGIN_OFFSET and AFTER_HOMING_POSITION
Anyways it seems to me you need to find out the distance (in machine units) from the homing trip point to where your center tool is in center of the spindle.
Set that as the HOME_OFFSET, it will be a positive number (because it looks like your home switch is on the positive limits)
Then set HOME = 0 (so it moves to spindle center after homing, if that is what you want. On a lathe you may not want it to, in which case you would set it something close to the HOME_OFFSET)
And then you will surely need to reset you MIN and MAX LIMITS.
So one way to estimate this (if you have access to measure)
move your center tool to be in line with the center of the spindle this is where you want the origin.
measure from the home switch trip dog to the home switch (or limit switch if that is what you use)
This is approximately the distance for HOME_OFFSET and for MAX_LIMIT
Approximate because you can't measure it accurately.
it will be positive because (it looks like) you reference with your positive side switch.
Then of course MIN_LIMITS will be the total_limits - MAX_LIMITS)
This would be the closest example in the docs:
linuxcnc.org/docs/devel/html/config/ini-...witch_example_layout
The difference is that you want the origin (B in the diagram) to be somewhere in the middle.
If you move the B you move the scale too so 0 is where the B is.
The other difference is your home switch is on the positive side so the signs change.
Hope I didn't lead you astray
- Ingo
Ingo
set HOME to the same as HOME_OFFSET or something very close - linuxcnc might not like sitting on the limit switchThen set HOME = 0 (so it moves to spindle center after homing, if that is what you want. On a lathe you may not want it to, in which case you would set it something close to the HOME_OFFSET)
Bit I'm confused by the negative ( -102,63 ) what switch are you using to home to?
