Version 2.8.2 Debian Buster PREEMPT-RT ISO Freezes
24 Jun 2022 22:29 #245813 by Muzzer
I installed kernel 5.10 as recommended by AndyP and that fixed my persistent freezing. I don't know if that would be appropriate but thought it may be worth mentioning.
forum.linuxcnc.org/38-general-linuxcnc-q...zing-solved?start=20
25 Jun 2022 02:14 #245835 by jcbryant
I had noticed your thread and did think that your problem sounded a lot like mine. I tried following the initial link that was supplied to you, but it's now broken.
At this point installing kernel 5.10 sounds like a very good thing to try. The only other options on the table are a complete re-install (in the hope that something went slightly wrong last time) and acquiring another computer
Where should I start?
26 Jun 2022 13:04 #245918 by Muzzer
I'm far from being expert / proficient / confident in this matter but I was able to install a more recent kernel without needing to reinstall Linux, LinuxCNC etc and that did the trick. The kernel is only one part of Linux, albeit the very core! And it's not unique to LinuxCNC.
It looks as if 5.18 is the latest stable kernel now.  www.kernel.org/  I don't recall what I did but it looks as if I simply installed it from the 5.18 tarball or the "latest release" icon. Pretty sure I didn't use the patch.
26 Jun 2022 21:57 #245959 by jcbryant
Sadly I fear that I'm even further from being proficient....
And I'm definitely confused on one point. It looks to me as if the kernels available from www.kernel.org are regular Linux kernels. Surely installing one on these without applying a RT patch would leave one with a kernel that was not suitable for use with a real time application like LinuxCNC?
26 Jun 2022 23:15 #245967 by tommylight
Try this in a terminal
sudo apt install linux-image-5.10.0-9-rt-amd64
after you do a
sudo apt update
26 Jun 2022 23:49 #245970 by jcbryant
?? I get "Unable to locate package linux-image-5.10.0-9-rt-amd64"
I did execute sudo apt update first.
Sorry for being so thick.
27 Jun 2022 00:03 #245972 by tommylight
No need to be sorry at all, i was just hoping it might work but i do not have where to test, so i used you as a "test subject" :).
Try this:
wget http://ftp.de.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-5.10.0-13-rt-amd64_5.10.106-1_amd64.deb
sudo apt-get install gdebi
sudo gdebi linux-image-5.10.0-13-rt-amd64_5.10.106-1_amd64.deb
27 Jun 2022 00:37 #245974 by jcbryant
bash: wget: command not found
I seem to be cursed!
27 Jun 2022 00:42 #245975 by jcbryant
OK - I am learning (slowly). wget installed....
27 Jun 2022 00:57 #245977 by jcbryant
The good news is that the install was successful;
john@Taig:~$ uname -a
Linux Taig 5.10.0-13-rt-amd64 #1 SMP PREEMPT_RT Debian 5.10.106-1 (2022-03-17) x86_64 GNU/Linux
The bad news is that when I tried running LinuxCNC it froze almost immediately.
Time to create page: 0.119 seconds
