Version 2.8.2 Debian Buster PREEMPT-RT ISO Freezes
- jcbryant
- Thank you received: 4
05 Jul 2022 22:07 #246683
by jcbryant
Replied by jcbryant on topic Version 2.8.2 Debian Buster PREEMPT-RT ISO Freezes
I seem to have solved the problem. I've exchanged the PC for another one of the same type and it seems to work fine. Admittedly it's early days, but I've had LinuxCNC running for quite some time without any freezes.
The only obvious difference between the two machines is that the BIOS on the new one provides a pair of Realtek PXE boot options that weren't there before. Perhaps this is a sign of subtle networking differences, and some aspect of the networking on the first machine wasn't compatible with LinuxCNC. Otherwise the two machines appear to be absolutely identical.
Not having a definite explanation for the freezes isn't very satisfying, but I'm very glad that I now have what seems to be a stable system.
Many thanks to those who replied. You've taught me a lot along the way.
- Thank you received: 4648
09 Jul 2022 14:55 #246947
The answer is, sadly, no.
It looks like it wants to work, but locks the machine solid during the setup phase.
At this point the machine locked up and auto-rebooted...
Replied by andypugh on topic Version 2.8.2 Debian Buster PREEMPT-RT ISO Freezes
I wonder if RTAI is an option? Kernel-mode RTAI won't work, but you can actually run LinuxCNC-uspace on an RTAI kernel.
But you probably have to build your own...
andypugh@rm-one:~/linuxcnc-dev/src$ uname -a
Linux rm-one 4.19.195-rtai-amd64 #5 SMP PREEMPT Sun Jul 11 19:13:27 BST 2021 x86_64 GNU/Linux
andypugh@rm-one:~/linuxcnc-dev/src$ halrun
halcmd: loadrt hostmot2
Note: Using LXRT realtime
halcmd: loadrt hm2_eth board_ip=192.168.1.121
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:10:00:08
hm2_eth: discovered 7I80DB-16
hm2/hm2_7i80.0: Low Level init 0.15At this point the machine locked up and auto-rebooted...
