How to read GPIO in real time?
4 years 2 months ago #249873 by chen1234
Guys, I'm using a raspberry pi as a controller,
and this controller needs to read a lot of GPIO (not including home and limits).
I'm trying to poll read GPIO using threads in my custom Glade UI.
But I found that this read is not timely and will be a little later than my signal.
How should I get these GPIOs, so that this IO can be read interrupted?
(I'm a newbie and don't know much about the underlying stuff)
Hope you can give me some advice?
thanks,chen
4 years 2 months ago #249889 by elovalvo
I think the best solution is to use the hal_pi_gpio module:
forum.linuxcnc.org/27-driver-boards/3770...r-raspberry-pi-gpios
The following user(s) said Thank You: chen1234
4 years 2 months ago #250512 by andypugh
Your GUI will never be able to respond to GPIO inputs in real=time as the GUIs are not realtime.
You should leave home and limits to be handled by the normal realtime motion module.
Time to create page: 0.271 seconds
