Setup spindle on Mesa 7i96s and Linuxcnc 2.8.3
4 years 2 months ago #250101 by prochj51
is it possible to connect to Mesa 7i96S analog interface for spindle with LinuxCNC 2.8.3.
It throws me an error that hm2_7i96s is not found, only the hm2_7i96 .
Thank you
George
4 years 2 months ago #250105 by PCW
Its possible (the 2.8 analog spindle setup would be identical to 2.9)
but you will still get the card name warning until you upgrade to 2.9
4 years 2 months ago #250107 by prochj51
So I should use hm2_7i96? Cause it does not work with hm2_7i96s ..
And what would be the pin for spindle_out, it seems it does not list me any.
4 years 2 months ago #250108 by PCW
You need to use hm2_7i96s (you will get a warning)
The spindle out is a PWMgen on a 7I96S
Upgrading to 2.9 would make this all simpler
Not just because of the card name issues but because
the 7I96S is supported by the graphic configuration utilities
in 2.9 (pncconf and mesact)
4 years 2 months ago #250110 by prochj51
I am on raspberry Pi 4 and hm2_7i96s throws me an error.
When I do for example
halrun loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" setp hm2_7i96s.0.watchdog.timeout_ns 5000000
LinuxCNC fails with pin hm2_7i96s.0.watchdog.timeout_ns is not found
4 years 2 months ago #250114 by PCW
Did the hm2_eth driver load properly?
