A(4th) and S (spindle) works on one same driver, possible?
07 Nov 2022 15:40 #256144 by Aciera
All the manual models, including the F3 in your link, have acme screws.
The following user(s) said Thank You: Masiwood123
  • Masiwood123
  • Masiwood123's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Nov 2022 16:35 #256154 by Masiwood123
in that case, I wouldn't dare to take it, there might be a lot of backlash...and it's certainly difficult to fit some new ballscrews. I need a small one mill for precise work, but in the cnc variant. Thanks a lot for the info
07 Nov 2022 20:14 #256161 by jpg
good evening, congratulations for your project, it is very successful, which version of linux do you use? The 2.8.4? and could you share your configuration, it would be useful for my project, thank you again, your video is very good
  • Masiwood123
  • Platinum Member
  • Platinum Member
07 Nov 2022 20:36 #256163 by Masiwood123
good evening Jean. I followed the installation instructions from JT (debian 12 bookworm).. then I installed the latest version available at the time from this link packages.debian.org/source/unstable/linuxcnc, since I use mesa 7i96s, it supports 2.8. 4. I will share the configuration tomorrow, but there is nothing special in it except 2mpg wheels that work like on a real lathe for x and z ..and this touch screen version of Axis gui..I will forward the link. This option to use the A axis and Spindle from the same driver has no settings in HaL, except for one output that on the servo driver changes the mode to command m64 and m65. if you have a similar Chinese servo motor I can explain how I connected it. My project can be followed on post #250685. what kind of machine are you making?
07 Nov 2022 21:03 #256164 by jpg
thank you, I would like to do an axis c tour, there are several options from what I could understand, yours, the angle offset (eoffset_per_angle) and orient, I test that on a Chinese bob and after, I pass on the tandem 5i25 / 7i76 as soon as the configuration will work, on the X Y axes, they are AASD -15 and vdf ALTIVAR (siemens) on axis c / spindel
  • Masiwood123
  • Platinum Member
  • Platinum Member
07 Nov 2022 22:09 #256167 by Masiwood123
Okay, I'm using the letter A because my Cam wood program is designed to work as 4th.axis. in my case for the Spindle drive motor, there is an ASSD servo motor. and its driver has the possibility of three modes of operation, position (step/dir) speed and torque... or a combination of position/speed, position/torque. at the input of the driver there is a pin that changes the operating mode, then that pin is simply defined and via the M command in linux it changes the position or speed (spindle). I only need the spindle for cutting pieces with a knife, I mostly use the headstock as the A axis. in your case, if I understood correctly, you have a classic high-frequency motor and that Siemens VFD (what model?)I assume that it only has speed mode as a control, in that case you should connect the encoder to 7i76, but I had no experience with those orient spindle settings in hal, i believe someone from the forum did. Another option that I had as a possibility at the beginning of my project is to put a classic spindle motor as a headstock, than to add another stepper motor that would connect to the spindle via a pneumatic cylinder and when spindle stops, drive the spindle like a classic rotary axis.I also think that you can't do anything with the bob card, it doesn't have an input for an encoder. You can describe the machine a little better (with a photos), that would help me and others to give better advice.
08 Nov 2022 06:00 #256189 by jpg
bonjour, voici une video
  • Masiwood123
  • Platinum Member
  • Platinum Member
08 Nov 2022 10:23 #256198 by Masiwood123
congratulations on the project, as I see a lot has been done, I just have a couple of dilemmas, even if you manage to make this asynchronous motor work in position mode, you would have to somehow lock it in that position, with a mechanical brake or whatever. since the VFD does not have a position mode, I guess...I would personally try it by taking an additional card that converts a digital to analog signal and has an encoder reading. something similar to this one on the link, I have 3 of them that work well, but I retrofit that machine to mach3 (I believe that linuxcnc is the same)... and then make a relay board and make some subroutine to remap m codes that will change, switch the analog signal to the VFD so that it sends the signal from the bob card for the S command, and also sends the analog signal via the relay board and this card as step/dir to analog for C command. I can't think of anything smarter at the moment :) Take a look to this card here www.audiohms.com/en/cnc-electronics-prod...otor-drive-dcs-100-a
08 Nov 2022 11:55 #256208 by andypugh
out of his, maybe you know, does this aciera have a ballscrew as a drive on axes?
I don't think so
www.lathes.co.uk/acieraf3/
But the same site has an old advert for one that had had them fitted, so is seems possible to do.
  • Masiwood123
  • Platinum Member
  • Platinum Member
08 Nov 2022 12:40 #256210 by Masiwood123
I tried to find it on the site, but I couldn't
