Homing Problems
23 Sep 2022 14:51 #252619 by Roger S
Homing Problems was created by Roger S
Hello everyone
I've been running my machine with the same configuration for almost two years. there were never any problems. as of today, homing on the x-axis no longer works. the machine drives over the switch without anything happening. I use inductive proximity switches. I checked the sensor, it works perfectly. when I trigger it manually, it does exactly what it's supposed to. the correct signal states are also displayed in the halshow when i trigger the sensor by hand. the switch then no longer reacts during homing. Does anyone have any idea what that could be?
  • Moderator
  • Moderator
24 Sep 2022 01:08 #252642 by tommylight
Replied by tommylight on topic Homing Problems
We might if we can have a look at the current hal and ini files found in the config folder.
24 Sep 2022 16:56 #252669 by Roger S
Replied by Roger S on topic Homing Problems
   here are the ini and the hal
File Name: roger.ini
File Size:5 KB
File Name: roger.hal
File Size:10 KB
  • Moderator
  • Moderator
24 Sep 2022 17:08 #252670 by tommylight
Use hal show to watch the input pins, see if they toggle when you trigger the switch by hand.
From a quick glance, the files look ok.
24 Sep 2022 17:33 #252671 by PCW
Replied by PCW on topic Homing Problems
Is it legal to have a HOME_FINAL_VELOCITY of 0?
24 Sep 2022 18:15 #252674 by Roger S
Yes, the signals are displayed correctly when I trigger them manually. The sensor only no longer reacts during referencing
24 Sep 2022 18:16 #252675 by Roger S
It always worked that way, but I don't know if it's right
24 Sep 2022 19:32 - 24 Sep 2022 19:32 #252680 by PCW
You may need to plot the joint 0 position + home-x with halscope
to debug this
Last edit: 24 Sep 2022 19:32 by PCW. Reason: sp
  • Moderator
  • Moderator
24 Sep 2022 20:23 #252684 by tommylight
Yes, it will move there at full speed.
Caused me some raised eyebrows when my big machine was doing that as full speed was set at 55 meters/minute and acceleration was at 7000mm/s/s! :)
25 Sep 2022 02:56 #252694 by PCW
Ahh the documentation says it moves at full speed to home if
HOME_FINAL_VELOCITY is unspecified so
HOME_FINAL_VELOCITY probably defaults to 0
The following user(s) said Thank You: arvidb
Time to create page: 0.117 seconds
