Homing Problems
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
26 Sep 2022 15:17 - 26 Sep 2022 15:18 #252774 by Todd Zuercher
Replied by Todd Zuercher on topic Homing Problems
You said the prox switch triggers manually, but does it trigger when you jog the machine to where it should be activated? Maybe the switch is out of adjustment or a piece of scrap is interfering with it.
Does the the hal pin "joint.0.home-sw-in" change when jogging the machine onto and off the prox switch.
Last edit: 26 Sep 2022 15:18 by Todd Zuercher.
The following user(s) said Thank You: arvidb, tommylight
Time to create page: 0.090 seconds
