Homing Problems
- Roger S
- Thank you received: 5
23 Sep 2022 14:51 #252619
by Roger S
Homing Problems was created by Roger S
Hello everyone
I've been running my machine with the same configuration for almost two years. there were never any problems. as of today, homing on the x-axis no longer works. the machine drives over the switch without anything happening. I use inductive proximity switches. I checked the sensor, it works perfectly. when I trigger it manually, it does exactly what it's supposed to. the correct signal states are also displayed in the halshow when i trigger the sensor by hand. the switch then no longer reacts during homing. Does anyone have any idea what that could be?
- Thank you received: 7462
24 Sep 2022 01:08 #252642
Replied by tommylight on topic Homing Problems
We might if we can have a look at the current hal and ini files found in the config folder.
- Roger S
24 Sep 2022 16:56 #252669
by Roger S
Replied by Roger S on topic Homing Problems
24 Sep 2022 17:08 #252670
Use hal show to watch the input pins, see if they toggle when you trigger the switch by hand.
From a quick glance, the files look ok.
- Thank you received: 5308
24 Sep 2022 17:33 #252671
Replied by PCW on topic Homing Problems
Is it legal to have a HOME_FINAL_VELOCITY of 0?
- Roger S
24 Sep 2022 18:15 #252674
by Roger S
Yes, the signals are displayed correctly when I trigger them manually. The sensor only no longer reacts during referencing
- Roger S
24 Sep 2022 18:16 #252675
by Roger S
It always worked that way, but I don't know if it's right
24 Sep 2022 19:32 - 24 Sep 2022 19:32 #252680
You may need to plot the joint 0 position + home-x with halscope
to debug this
to debug this
Last edit: 24 Sep 2022 19:32 by PCW. Reason: sp
24 Sep 2022 20:23 #252684
Caused me some raised eyebrows when my big machine was doing that as full speed was set at 55 meters/minute and acceleration was at 7000mm/s/s!
Yes, it will move there at full speed.Is it legal to have a HOME_FINAL_VELOCITY of 0?
25 Sep 2022 02:56 #252694
Ahh the documentation says it moves at full speed to home if
HOME_FINAL_VELOCITY is unspecified so
HOME_FINAL_VELOCITY probably defaults to 0
The following user(s) said Thank You: arvidb
Time to create page: 0.127 seconds
