SOLVED - 6i25 Can't see swicthes change from test box
- macsddau@linuxcnc
- Thank you received: 29
29 Sep 2022 08:30 - 29 Sep 2022 08:31 #253000
by macsddau@linuxcnc
SOLVED - 6i25 Can't see swicthes change from test box was created by macsddau@linuxcnc
When I was using the mother board parport I have made a test box.
This box is wired according to this schema:
The HAL follow this pinout:
Using test box has no reponse in linuxcnc. Is there something wrong with theese datas ? I suspect 6i25 output voltage and 10k pullup/pulldown resistors of the test box.
# --- MACHINE-IS-ENABLED ---
setp hm2_5i25.0.gpio.007.is_output true
net machine-is-enabled => hm2_5i25.0.gpio.007.out
# external input signals
#--- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.gpio.003.in_not
# --- HOME-X ---
net home-x <= hm2_5i25.0.gpio.013.in
# --- HOME-Y ---
net home-y <= hm2_5i25.0.gpio.014.in
# --- HOME-Z ---
net home-z <= hm2_5i25.0.gpio.015.inUsing test box has no reponse in linuxcnc. Is there something wrong with theese datas ? I suspect 6i25 output voltage and 10k pullup/pulldown resistors of the test box.
Last edit: 29 Sep 2022 08:31 by macsddau@linuxcnc.
- Thank you received: 7462
29 Sep 2022 09:44 #253007
Replied by tommylight on topic SOLVED - 6i25 Can't see swicthes change from test box
Mesa 6i25 inputs have their own pullups, so they need to be grounded to trigger.
Shorting them to gnd works, or use a DVM set in Diode mode, red probe on gnd, black probe on inputs.
- macsddau@linuxcnc
29 Sep 2022 09:51 #253009
Replied by macsddau@linuxcnc on topic SOLVED - 6i25 Can't see swicthes change from test box
Did I have to move W4 down to disbale 6i25 internal pullup resistors ?
29 Sep 2022 09:52 #253011
No.
- macsddau@linuxcnc
29 Sep 2022 10:04 #253012
Is ther any shcmatics for shorting to gnd or dvm set ?
I don't know what is is a "a DVM set in Diode mode".Mesa 6i25 inputs have their own pullups, so they need to be grounded to trigger.
- macsddau@linuxcnc
29 Sep 2022 10:09 #253013
The test box works with parport. Wiring is OK.
Internet is your friend. I kwon what is dvm.
29 Sep 2022 10:09 #253014
DVM = digital volt meter
The following user(s) said Thank You: macsddau@linuxcnc
- macsddau@linuxcnc
29 Sep 2022 10:13 #253015
I will make a new test box
- macsddau@linuxcnc
29 Sep 2022 10:36 #253017
29 Sep 2022 11:35 #253023
No need, you can invert inputs by adding "_not" to input pins in hal.
Time to create page: 0.263 seconds
