Move Axis before going with custom button
- chrischan
02 Oct 2022 08:25 #253229
by chrischan
Replied by chrischan on topic Move Axis before going with custom button
2.7 axis
- Thank you received: 2173
02 Oct 2022 15:09 #253258
Replied by cmorley on topic Move Axis before going with custom button
You must use gladevcp for this.
Depending on the version of linuxcnc you may or may not require a python handler file.
get a gladevcp panel with a button working then we can go from there.
This is what I'm thinking we can use:
linuxcnc.org/docs/devel/html/gui/gladevc...l#_vcp_action_python
- chrischan
02 Oct 2022 15:53 #253262
by chrischan
Ok. I will check for gladevcp
02 Oct 2022 16:13 #253263
Ok with 2.7 we will need to use the handler file as the widget I quoted is not available.
Only a slightly more difficult.
Time to create page: 0.341 seconds
